One more questoin before I give up.
Username: Rideredder
Cornell, IL USA
Post Number: 1148
Alright, I finally got one of my videos edited to my liking to post on Youtube and when I go to upload it it says "invalid file format". I couldn't find anywhere that it asks you what format you want.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13239
what format are they in???
Post Number: 13240
Im almost positive they use any Wma, .avi, .mov, and .mpg
and maybe even divx, not sure on that tho
Cornell, IL USA
Post Number: 1149
Well, I'm using Windows Movie Maker to edit them. I found it under My Videos and tried it. How do I find out which format this video is?
Post Number: 13242
right click it...and go to properties should be near the top
Username: Luisdelbronx
Bronx, NY USA
Post Number: 208
You are probably trying to upload your actual project file. open up your project with movie maker then go to step 3 and save to your computer and it should save with .wmv and you can then upload that file to youtube.
Cornell, IL USA
Post Number: 1150
Is it good or bad that it's been processing for a half-hour now?
Username: Livin_loud
Do Work Fi Audio
Post Number: 1971
5 min clip for me takes about... 5 min lol
Bronx, NY USA
Post Number: 209
Depends on how long the actual video is...and how fast your computer is. If the vid is short and your computer is decently fast then its probably stuck.
Try right clicking the file being created and hit properties..check the size, then wait a few and check again, if it gets bigger and bigger then its working, if its still the same size after a while then its stuck.
Cornell, IL USA
Post Number: 1151
Alright thanks guys. I think I got it working now.
