Pansat 2700 - BUGS FIXED
Username: Asharfi
Post Number: 1494
There was a bin for the original Pansat 2700 units which fixes the channel freezing problem. I've posted the bin at www.dssworld.co.nr, just in case if you need it. THIS BIN IS NOT FOR CLONES and/or the CONVERTED UNITS.
Expect bin for clones and the converted units by tomorrow.
Username: Rtap
FL
Post Number: 1190
always on top of your game.lol whats up AV.hows life treating you.
Username: Asharfi
Post Number: 1496
Good ... bought a dish 500 few weeks ago ... still in a box ... planning to install this weekend to get BEV, too .... is there a way to install without using any meter?
Username: Cartier1
Post Number: 1425
av . sure . u need either a small tv and the box on the place where u gonna use the instalation . or someone has to be front of the tv while you afre pointing .
easy to do without any meter . you need to know the elevation and the asimuth where to pint .
but the most important is installing the hand .the rest is easy
check this :
http://satcalculator.freehostia.com/
Username: Ke5aqn
Post Number: 951
"the most important is installing the hand"
what are you saying?
Username: Cartier1
Post Number: 1428
what i ,meant by the hand is the wall mounth.
the rest is simple . i instal maybe more than 3 a day without meter. it become habit
Username: Sitsat
Post Number: 134
AV, thanks for updating us. Is this new bin also from TeamBlacklist? I was only able to find one bin (224) after the last ECM at FUTUREFTA. Did they release two bins for original 2700A after the last ECM on November 21st?
Username: Shadycove
Post Number: 141
use dishpointer.com and you prolly won't need anything else
Username: Asharfi
Post Number: 1498
Yes, this updated bin is from TeamBlacklist which was released on November 26, 2007.
Username: Sitsat
Post Number: 135
Thats good news :-) Thanks AV! I'll give it a try tonight.
Username: Nydas
Post Number: 5304
There does not seem to be any rush to put out a clone version or the conversion version of the latest change in the original file 2 days ago.
