Bronze Member Username: HddvdPost Number: 11 Registered: Nov-07 | I got some new 12 inch subs. When i play them loud i can hear a clicking noise. Another way of describing the sound is as if something was flicking the back of the subwoofer cone. Can someone explain what this sound might be. |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13229 Registered: Jul-05 | need more info on ur system...sounds like ur overpowering ur sub... what type of subs and amp do u have?? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4210 Registered: Jul-06 | Tinsel slap perhaps |
Bronze Member Username: HddvdPost Number: 12 Registered: Nov-07 | well... here is the thing. I have 2 polk mm2124dvc. They are actually being underpowered. This is they amp i am testing them on: http://www.alpine-usa.com/US-en/products/product.php?model=MRP-M850 |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 5974 Registered: Jul-06 | Maybe your subs are bottoming out. What kind of enclosure are your subs in? |
Bronze Member Username: HddvdPost Number: 13 Registered: Nov-07 | they are in a dual .88 cubic feet sealed enclosure. that is what polk recommends. |
Gold Member Username: Freezeman_7FOR SALE, BNIB RD AUDI... USA Post Number: 2154 Registered: May-06 | i would guess tinsel slap.. |
Gold Member Username: Mike11202DD9515G VFL 200.1 = : , Sewell, NJ US Post Number: 1099 Registered: Nov-06 | Thats what my Fi Q used to do...... |
Bronze Member Username: HddvdPost Number: 14 Registered: Nov-07 | is there anyway to get this issue fixed? |
Gold Member Username: SouthernrebelMonroe, Louisiana 2 DD3515s, 2... Post Number: 5598 Registered: Mar-04 | IIRC, the tinsels are woven on that sub. I'm guessing they are bottoming out...or you're clipping the amp. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 6003 Registered: Jul-06 | "Thats what my Fi Q used to do......" That's because it was USER ERROR Mike. How do you feel about me saying that? |
