JBL Amp
Username: B3n07
Louisville, Ky USA
Post Number: 605
are these amps any good and if i was to run 4 subs of a mono block at 600 watts wouldnt i need atleast2400 watts to do so from this one amp
Username: The_image_dynamic
San Diego
Post Number: 3144
Which model and.... huh?
Username: B3n07
Louisville, Ky USA
Post Number: 606
i was wounding if on a mono amp if i run mutliple sub off this would i need to multiply the power i neeed for each by the number of subs to figure up a base number of power to get in the amp right
i am looking at runing two gto 1201.1 with 4 infinity perfect kappas in a custom built box vented to the lowest they can go
