Can we upload files from PANSAT 2700A to Computer
Username: Ozziejatt
Post Number: 18
Can we upload files from PANSAT 2700A to Computer.
problem is i dont know what my receiver is and what file it would take. This will allow me to see what type of file was loaded earlier and i can load new bin accordingly
Thanks
Username: Ke5aqn
Post Number: 946
It does not matter what has been put in before.
The new fix for that receiver is at FUTURE.
Just go get it, do a factory reset, install the new bin, set up antenna settings, scan sat's and watch tv..
Username: Ozziejatt
Post Number: 19
Thanks very much sir another thing that i read here in these forums?
is there a difference in files i mean Pansat 2700A and Pansat 2700A B-75?
i just want to make sure i put the right file in
Username: Ke5aqn
Post Number: 947
I pointed you to the fix for that receiver from the home forum for that receiver you can always trust them..
