Cs5k, bin 155, dish, and weird behaviour
Username: Bich_d
Toronto
Post Number: 27
before bin 155 (c00ls$t 5k), i was fine on DN.
they changed the security stuff.. got the new bin.
It now works, but i have to soft reset the recver every time i change the channel.
If i change the channel, the signal 'appears' to be gone, and i get scramble channel, or some other error. I soft reset, and vola, good signal, and i'm watching tv.
anyone else have this issue?
Username: Lroy
Post Number: 332
Try this:
1. Do a factory reset
2. Load factory bin coolsat5000_100_20051007.stb
3. Factory reset again
4. Load latest fix COOLSAT5000_NORW_155_20071123.stb
5. Factory reset again then rescan and you should be good again.
It may take a little time but it woun't cost anything....
