Silver Member Username: Dubmc23Rapid City, SD USA Post Number: 120 Registered: Sep-07 | what exactly is the big 3?? |
Gold Member Username: HdubbTeam Revolution Post Number: 2963 Registered: Nov-04 | its upgrading the stock wires that are hooked up to your alternator. |
Gold Member Username: Tremor1127Fi Post Number: 2497 Registered: Aug-06 | alternator to battery wire battery to chassis wire chassis to engin wire all three upgraded. the bigger the wire the better. unless your only doing up to 1000wrms... |
Silver Member Username: Dubmc23Rapid City, SD USA Post Number: 122 Registered: Sep-07 | hmm still kinda confused but that helped out alot lol thanks guys...would i have to do it running a kx1200.1 on a honda civic stock alt?? |
Gold Member Username: Andrew571Stillwater/Edmond, Oklahoma USA Post Number: 1310 Registered: Oct-05 | it would be better, but if ur strained on budget.... u can probabl get by... see how bad the voltage drops are, and if they r bad then wire it up! |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4177 Registered: Jul-06 | If you have a stock alt you don't need a big 3 upgrade. If your voltage is dropping that means you need an HO alt, and then of course the big 3 upgrade is needed to handle the increased output of the alternator. |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13223 Registered: Jul-05 | even with a stock alt the big 3 can only help |
Gold Member Username: BernymacTurtles have four legs Post Number: 3446 Registered: Sep-04 | http://www.fullsizechevy.com/forums/general-discussion/audio-video-electronics/2 50724-big-3-then-1-a.html |
