Noob question.....
Username: Dubmc23
Rapid City, SD USA
Post Number: 120
what exactly is the big 3??
Username: Hdubb
Team Revolution
Post Number: 2963
its upgrading the stock wires that are hooked up to your alternator.
Username: Tremor1127
Fi
Post Number: 2497
alternator to battery wire
battery to chassis wire
chassis to engin wire
all three upgraded. the bigger the wire the better. unless your only doing up to 1000wrms...
Username: Dubmc23
Rapid City, SD USA
Post Number: 122
hmm still kinda confused but that helped out alot lol thanks guys...would i have to do it running a kx1200.1 on a honda civic stock alt??
Username: Andrew571
Post Number: 1310
it would be better, but if ur strained on budget.... u can probabl get by...
see how bad the voltage drops are, and if they r bad then wire it up!
Username: Nd4spd18
Northwest PA
Post Number: 4177
If you have a stock alt you don't need a big 3 upgrade. If your voltage is dropping that means you need an HO alt, and then of course the big 3 upgrade is needed to handle the increased output of the alternator.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13223
even with a stock alt the big 3 can only help :-)
Username: Bernymac
Turtles have four legs
Post Number: 3446
http://www.fullsizechevy.com/forums/general-discussion/audio-video-electronics/2 50724-big-3-then-1-a.html
