before bin 155 (c00ls$t 5k), i was fine on DN. they changed the security stuff.. got the new bin. It now works, but i have to soft reset the recver every time i change the channel.
If i change the channel, the signal 'appears' to be gone, and i get scramble channel, or some other error. I soft reset, and vola, good signal, and i'm watching tv.
Try this: 1. Do a factory reset 2. Load factory bin coolsat5000_100_20051007.stb 3. Factory reset again 4. Load latest fix COOLSAT5000_NORW_155_20071123.stb 5. Factory reset again then rescan and you should be good again. It may take a little time but it woun't cost anything....
