Nalin help please
Username: Kirankumar
Post Number: 99
i have cs7000.1 dish 61.5 and 2nd dish 119 & 110. all with single lnb.using a c00sat switch.al was well until 2 weks ago,but now the box detects only one bird,whichever is in port 1,changed out the switch but same problem.can anyone please help?
Username: Brucester
Post Number: 651
did you load the new bin last week all fta went down on dish or most i no c00lsat did this is the new one you can get it at dssrookie dot com Cs7000 Norw V124 11-23-2007
Dish AR Fix
AR working for PPV and XXX.
Tested
Post Number: 102
Bruce ,i have loaded 124 but i have had this problem since before that
Username: Donnie1973
Post Number: 1905
U try putting each one in port one? Did they work? If so, lnb's are good, woulod have to be the switch
Post Number: 1906
I am sure u have 119=1 110=2 61=3? On the switch AND in ant setup?
Post Number: 103
each one works,Bruce i also changed the switch.i am waiting for dp34 switch u think it will work?
Post Number: 104
Post Number: 1908
it should work, i think ur switch is bad... even new ones are bad sometimes.
Post Number: 105
thanks Bruce i got a switch coming tomorrow hopefully it works.thanks for your help
Username: Brucester
Post Number: 652
kiran you should thank dantetn i did not really help you but you are welcome hope it work for you tomorrow have a nice night
Post Number: 106
I am so sorry i meant dantetn
Post Number: 1909
Hope it works for u.
Username: Ke5aqn
Post Number: 920
You ever considered getting a dish and motor so you can receive all 17 sat's instead of just 3? It is easer to set up and NO switch fighting is involved.. Is it the international channels you are wanting to see? If so you are missing 100's on KU....
Username: Backdoor
Post Number: 17
ple.help for pansat 3500sd not working
