Silver Member Username: Pbplayer05Carroll, Iowa Post Number: 136 Registered: May-07 | not to sure about it i was looking at getting a ta8101 which says that it does 1500 at 1 ohm rms not sure though anyone know anything about mtx |
Gold Member Username: camPost Number: 1223 Registered: Nov-06 | MS says they blow. He knows what he's talking about, so I'd look elsewhere. Someone else will recommend you an amp that they have had experience with. |
Bronze Member Username: Homeboi88Lexington , Kentucky United states Post Number: 86 Registered: Apr-07 | naw dat aint tru mtx under rates there products an my friend has three an they have never blown u jus gotta hook it up rite |
Gold Member Username: camPost Number: 1226 Registered: Nov-06 | I'll bet. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4349 Registered: Jul-06 | They are accurately rated, but as far as quality, thats another story. Not as bad as pyramid, pyle, sony, etc. but they're down there. |
Silver Member Username: Pbplayer05Carroll, Iowa Post Number: 137 Registered: May-07 | ya thats what i was thinking also anyone know anything about swiss audio i fond one of there amps for like 250 and it says 1500watts rms not sure though |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 5053 Registered: Dec-05 | i wouldn't look swiss audio too much. What are you trying to push and budget please |
Silver Member Username: Pbplayer05Carroll, Iowa Post Number: 138 Registered: May-07 | well im looking for a friend and he dont have the budget that i had when i bought my stuff and i wasnt sure about them or not they look ok but has anyone used anyof there stuff before? ill prolly just tell him to get audioques new amp and some of there stuff cuz i know thats decent equipment i have a sae-1000d and 2 12inch si bm's |
Gold Member Username: camPost Number: 1236 Registered: Nov-06 | eD is doing real cheap b-stock amps now. NINe.1 is $250. http://www.edesignaudio.com/edv2/advanced_search_result.php?keywords=b-stock |
Silver Member Username: Pbplayer05Carroll, Iowa Post Number: 141 Registered: May-07 | well would thjat be better than the audioque amp though cuz they are pretty cheap right now |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4389 Registered: Jul-06 | Audioque amp would be better |
Silver Member Username: CblazeRock island, Tenesssee Us Post Number: 630 Registered: Sep-07 | i had the ta 4501,they are reliable,and a lil underrated but not topline,the msrp on them is crazy,u can get better for the money |
