Silver Member Username: NorthomahaPost Number: 619 Registered: Mar-06 | Anyone recommend any places to buy fiberglass supplies for a project such as the fiberglass cloth and the resin, i dont want to go to lowes and get it, ive heard bad reviews of hardware store resin |
Gold Member Username: Crayola02008 Nissan Versa!!, Wisconsin Post Number: 2224 Registered: Jun-06 | i think i remember people talking about going to like a boating store cause fiberglass is used to repair boats and stuff |
Silver Member Username: NorthomahaPost Number: 622 Registered: Mar-06 | yea, well im doin this project when i go home to nebraska and theres not a lot of boating stores there, anybody got internet sites? |
Bronze Member Username: Basebalz13Moneta, Va Usa Post Number: 92 Registered: Aug-07 | look on ebay under ebay motors_ parts and accesiors_boats then in the search type in fiberglass mat or cloth which ever you prefer or if you need resin type that in, i think you can only get it by the gallon though buts its the best prices ive seen |
Silver Member Username: NorthomahaPost Number: 623 Registered: Mar-06 | ill check that out, the more and more i read install threads im reading that there is a huge difference in the type of fiberglass you use quality wise, also the resin. has anyone here done an install that can give me a review |
Gold Member Username: BernymacTurtles have four legs Post Number: 3443 Registered: Sep-04 | www.uscomposites.com |
Silver Member Username: NorthomahaPost Number: 626 Registered: Mar-06 | thanks berny, did you use any of these? |
Gold Member Username: BernymacTurtles have four legs Post Number: 3444 Registered: Sep-04 | yeah, I bought all my supplies there. I used the B-440 Premium Polyester Layup Resin, 4" width 1 1/2oz Mat Tape. I got some brushs at harborfreight. |
