Quick amp/box question, plz help
Username: Leapoldstotch
im getting a 12" type r
i wanna get the alpine m450 amp,
# 220W x 1 @ 4 ohms
# 400W x 1 @ 2 ohms
# 600W x 1 Brigded 4 ohms
600w rms will be plenty to power the 500rms type r right? and it is possible to bridge a mono amp? its only got 1 channel..
also my box is going to be
# Dimensions (W x H x D): 30" x 13.5" x 16"
ported tuned to 32 hertz
it says its only 2 cu ft. but if my math is right its 3.75? and i heard this would be the best possible box since its pretty large for a single 12" type r.
Username: •cam•
Post Number: 1121
Nope, you can't bridge a single channel, since bridging requires two channels by definition.
You're getting 3.75, because you're calculating the space the box will take up. You need to subtract 1.5 from each dimension, to get the internal volume. Don't forget to take into account sub displacement and port displacement.
ohh ic, but wont this still be a very nice box for the type r 12"? i keep looking at the much smaller boxes that are like cubes but everyone says the bigger the box the better. and this box is said to be made to alpine specs for the type r.
and would 400 watts be plenty for the 500 watt type r? any tips on amp/box would be great
Username: Fred_sanford
Huntsville, Alabama Usa
Post Number: 18
as far as the amp goes alpine rates that amp for 400 watts @2 ohms, where did you get the 600watt spec.? Cam is right about the box, wood thickness eats airspace
Username: •cam•
Post Number: 1122
I have no idea, never even heard one. You'd probably be fine with 400 W. There are people far more suited for R specific questions than I, on this forum.
Post Number: 7
im pretty sure it will be fine. i really just dont wanna spend 90 bucks on a nice box when the 30 dollar ones that are half the size "the box ones" are fine. but everyone says the box literally is everything.
Post Number: 9
http://cgi.ebay.com/12-ALPINE-TYPE-R-SUB-ENCLOSURE-SWR-1222D-SWR-1242D-BOX_W0QQi temZ150186241569QQihZ005QQcategoryZ50568QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
this actually with be the box im getting. any help on a better one that is possibly cheaper?
