Well I have an 05 camry and woodlawn said it might be hard to get my box size up to dd reccomended specs and I kno dd's need big boxes so I was wondering what are the minimum measurements I can get away with like how many inches height how many inches width and depth so on and so on so I can measure my trunk bcuz I plan on ordering 2 2512's today but not if they won't fit in my trunk I dnt see why they won't my trunk isn't smalll.
3.5ft^3 is the minimun net size so probly 4.2ft^3 for the total cu ft. try and make bigger though if you can.
just incase you didnt know ho to get cuft you multiply all the sides so if the box was 12"x14"x20" you multiply them together. =3360 then divide by 1728=1.94ft^3 and thats how ya do it
Ok so 39"x14.5x22 will be too small for the dd's because if I remember the correctly that is the biggest box possible that can fit into my trunk 39 width 14.5 height 22 depth
