Want to get 129 w/ Dish 1000, Need Help
Username: Yeagermeist
I have VS9000HD, with 8psk module installed. I have a dish 1000 antenna up with 3 single dishpro lnbs and a dp34 switch. I have a signal strength of 68 and quality %69 for 110 and 119. Both sats are recognized by my stb. However 129 only has a signal strength of 56 and quality is 0 zero, the stb does not recognize that signal is sat 129. I am getting the few HD channels from 110/119 just fine. Will the 1000 not work with 3 single dishpro lnbs? Or better yet, can anyone tell me the best set up to get all HD channels from 110,119, and 129. Thanks.
Username: Tale
Post Number: 30
Are You sure that You have a LINEAR LNB aimed to 129 ?
Username: Rtap
FL
Post Number: 1156
its not a linear lnb for 129 its a circular lnb.
Here is a list of satellites and the correct lnb's to use with them:
61.5W Echo 3 - use standard circular lnb - 11250 MHz
63W Estrela - use linear lnb, either universal or standard linear- 10750 MHz
71.8W Nahuel 1- linear lnb, either universal or standard linear- 10750 MHz
77W Echo 4 - circular standard lnb - 11250 MHz
79W Amc 5 - linear lnb, either universal or standard - 10750 MHz
82W Nimiq 2 - circular standard lnb= 11250 MHz
87W Amc 3 - --- linear lnb, either universal or standard - 10750 MHz
91W Galaxy 11- linear lnb, either universal or standard- 10750 MHz
91W Nimiq1&3- circular lnb standard= 11250 MHz
93W Intelsat 6- linear lnb, either universal or standard-10750 MHz
95W Galaxy 3c- linear lnb, either universal or standard - 10750 MHz
97W Intelsat5- linear lnb, either universal or standard - 10750 MHz
101W Amc 4 - linear lnb, either universal or standard- 10750 MHz
103W Amc 1- linear lnb, either universal or standard- 10750 MHz
105W Amc 15- linear lnb, either universal or standard- 10750 MHz
107.3W Anik - linear lnb, either universal or standard- 10750 MHz
110W Echo 8 & 10,X - circular lnb standard - 11250 MHz
111W Anik f2 - linear lnb, either universal or standard - 10750 MHz
116.8W Satmex5 - linear lnb, either universal or standard - 10750 MHz
119W Echo 7 - circular lnb standard - 11250 MHz
121W Echo 9 - linear lnb, either universal or standard - 10750 MHz
123W Galaxy 10r - linear lnb, either universal or standard - 10750 MHz
127W Galaxy 13 - linear lnb, either universal or standard - 10750 MHz
129W Echo 5 - circular lnb standard - 11250 MHz
148W Echo1 & 2 - circular lnb standard - 11250 MHz
Username: Tale
Post Number: 31
You are right RTAP ,sorry I mixed it up with ECHO 9 !!!
Username: Rtap
FL
Post Number: 1157
no problem me ta i help you,you help me we are all one big happy family.lol
All three LNBs are identical, and it appears that all three sats use the same type. Mine are Dishpro Digital dual LNBf
Does anyone know if my setup should work? I am trying to narrow my problem down. If I know that this setup is working for someone else, then maybe it could be an aiming problem, or something like a tree branch in the way....
I still need help....please
