Fiberglass supplies
Username: Northomaha
Post Number: 619
Anyone recommend any places to buy fiberglass supplies for a project such as the fiberglass cloth and the resin, i dont want to go to lowes and get it, ive heard bad reviews of hardware store resin
Username: Crayola0
2008 Nissan Versa!!, Wisconsin
Post Number: 2224
i think i remember people talking about going to like a boating store cause fiberglass is used to repair boats and stuff
Post Number: 622
yea, well im doin this project when i go home to nebraska and theres not a lot of boating stores there, anybody got internet sites?
Username: Basebalz13
Moneta, Va Usa
Post Number: 92
look on ebay under ebay motors_ parts and accesiors_boats then in the search type in fiberglass mat or cloth which ever you prefer or if you need resin type that in, i think you can only get it by the gallon though buts its the best prices ive seen
Post Number: 623
ill check that out, the more and more i read install threads im reading that there is a huge difference in the type of fiberglass you use quality wise, also the resin. has anyone here done an install that can give me a review
Username: Bernymac
Turtles have four legs
Post Number: 3443
www.uscomposites.com
Post Number: 626
thanks berny, did you use any of these?
Username: Bernymac
Post Number: 3444
yeah, I bought all my supplies there. I used the B-440 Premium Polyester Layup Resin, 4" width 1 1/2oz Mat Tape. I got some brushs at harborfreight.
