Please could someone help a newbie
Username: Denon
i just bought a new sound system for my car and i took it to my local audio installer and he said that my car would just struggle to power it
so i asked if i bought a bigger battery and alternater would that work he said it would but i would also need a power cap
when i asked what size battery and alternater i would need he said said he didnt know which has left me in a pickle because i dont know who else to ask so ive tried here to see if anyone can help
my car is a
suzuki vitara jlx 2door soft top 1992 model
and the battery is only small so im assuming that the alternater is only small to
ill list the amps below that i bought
HIFONICS GENERATION XX SERIES XX COLOSSUS II 3,200 WATT RMS DUAL MONO-BLOCK CAR AMPLIFIER
this will be powering 2x 4000watt subwoofers
and i bought a 4 channel amp to give the 4 car door speakers better sound thats a
JENSEN JPA-460 600w 4/3/2 CHANNEL CAR AMPLIFIER AMP
please if someone knows could they tell me or point me in a direction on what size battery and alternater i would need and where id be best buying one from
also would i need a certain type to fit my car or do most alts fit most cars.
also if possible if i list the items i bought would someone be able to have a look and send me a wiring diagram or a step by step guide to explain/show how i would wire it up as it would save me alot of money
the items i bought ill list below
http://audiosavings.com/product_details.aspx?item_guid=512bfe43-922c-4258-ba76-6 fc915c5de3e&category_guid=ae183c37-906d-46ae-836c-f5b5c6d4305f
this next amp is to power the 4 car door speakers
http://cgi.ebay.com/NEW-JENSEN-JPA-460-600w-4-3-2-CHANNEL-CAR-AMPLIFIER-AMP_W0QQ itemZ270180026585QQihZ017QQcategoryZ39739QQcmdZViewItem
and these are the 4 speakers i got for the amp for the doors
http://audiosavings.com/product_details.aspx?item_guid=73cdd973-abf9-4652-8c25-d 9db1902fe0d&category_guid=219420be-b87b-4170-b250-5d61698437a9
and i bought this wiring kit for the jensen amp above
http://audiosavings.com/product_details.aspx?item_guid=10a371ff-59ec-46ad-ab67-1 11861eaa058&category_guid=b4b9f579-9efa-4066-96b4-4cd6d0709731
hope this makes sense and hope someone can help thanks
