Wuts the difference DD
Username: Basebalz13
Moneta, Va Usa
Post Number: 88
wuts the differnece between the 9515 D motor and F motor help please need to know quick
Username: J_baby15
Murray, Kentucky
Post Number: 2068
D is the triple stacked w/ chrome i believe, f is double stacked. theres going to be some adjustments in cooling and things like that. the Strength of the motors will probably vary also, but i dont know much about that.
Username: Somedonniedude
Illinois United States
Post Number: 456
Is the F there newer motor?
bUmp^^^
Username: Logan__tille
HEMIKLR
Post Number: 9083
Yepp ^^^
Username: Th3pwn3r
Post Number:...
Post Number: 5936
"Yepp ^^^"
Wrong dumb a ss.
www.ddaudio.com
HEMIKLR
Post Number: 9088
What? The D is newer than the F?
Username: Zacdavis
Beloit, Wi
Post Number: 668
yes the F is newer than the D, and it has more motor force than the D as well.
Username: Th3pwn3r
Post Number:...
Post Number: 5938
http://www.ddaudio.com/dd/caraudio/woofers.asp?series=9500g
The D also has spring terminals and the F has direct wire connection.
Username: Th3pwn3r
Post Number:...
Post Number: 5939
http://www.putfile.com/pic.php?img=7116070
http://www.putfile.com/pic.php?img=7116073
D and F motors side by side.Sorry for calling you a dumb a ss but the G series is there newest series?
HEMIKLR
Post Number: 9090
lol Its alright :-). Yea I believe the G is the newest so far.
Username: Rovin
4 10 Pioneer...
Post Number: 12509
er - i would think they\dd naming each series after the alpahbet would have made it obvious as to which model is newer
A|B|C|D|E|F|G series ...
