New member Username: Jonny_bKellogg, Idaho U.S. Post Number: 4 Registered: Oct-07 | KICKER S8L5 SOLOBARIC 8" 2 OHM is the sub im going to buy, these little guys put out 300 watts rms. my question is like almost everyone elses WHAT AMP!!! i currently have a 440 watt 2 channel amp. would that power one? also when figuring out what amp to buy you match the rms rating of the speaker what on the amp? thanx |
Silver Member Username: SomedonniedudeIllinois United States Post Number: 443 Registered: May-07 | What is the model and brand of the amp you have? Alot of 2 channel amps put out power @ 4 ohms when bridged. If it will do that, then that amp will work. |
Gold Member Username: JohnfiacA-ToWn, Bangn aint easy ....when u g... Post Number: 3905 Registered: Mar-06 | kicker 400.1 |
Silver Member Username: KaerfplSpencerport, NY USA Post Number: 743 Registered: Jun-06 | You can wire that sub into two ways: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22 Just curious but is that a SVC or DVC 2ohm? All the L5's I found were DVC. Like SomeDonnieDude said, most 2-channel amps will be able to be bridged into a 4ohm load. If that amp will put out enough watts to power the L5, then go for it. If not, then you can look into some of these amps: http://www.sonicelectronix.com/item_6521_Hifonics+BXi+606.html http://www.sonicelectronix.com/item_6471_Alpine+MRP-M650.html http://www.sonicelectronix.com/item_7422_JBL+GTO601.1II.html http://www.sonicelectronix.com/item_3006_Memphis+16-PRD500.1.html http://www.sonicelectronix.com/item_7561_Orion+HCCA-D600.html http://www.sonicelectronix.com/item_6527_Hifonics+ZXi+4006.html http://www.sonicelectronix.com/item_2099_Kicker+KX350.2+KX-Series+04KX350.2.html http://www.sonicelectronix.com/item_6725_Orion+HP-2600.html |
