I tried this and it works good and it save a lot of time instead of resetting the box back up after a factory default. Mods feel free to make a sticky if you think it is worth it. sAVE Your settings!!! Save time & trouble! Are you tired of having to rescan sats, make changes to lnb and switch settings, readjust the TV picture settings and everything else that you have spent time adjusting everytime you do a new "bin" file upgrade???
Well, your problems are over, did you know that you can save ALL of your current settings easily by using one of the Menu features?
>Open the "Menu" >"System Setting" >"User Channel List" then click on "Save..."
and save your current settings exactly the way they are, just be sure to have everything working the way you like it, then make up a short name such as "List 1" or any name you please and then Exit from the Menu and there you have it!
All of your settings are saved! Then after you do the next "bin" file upgrade, all you have to do is Load it and WaLa!!!
After the next "bin" file fix comes out, do the upgrade as usual, then:
Open the "Menu" >"System Setting" >"User Channel List" then click on "Load..."
and select the name that you previously created (i.e. "List 1") then answer "yes" to load the stored settings, then Exit from the Menu once it has loaded the settings, it will now be exactly the way it was before, it will even pop up to the last channel you were watching when you saved the settings.
In the future when any changes have been made to your settings such as rescanning satellites for channel changes/updates or edits to anything imaginable, you can create another "Save..." list and every change will be saved in a new "User Channel List" file.
It only takes about 1 minute to "Load..." a saved list compared to all the grief of scanning satellites and making all the lnb and switch settings again.
I hope this will benefit all CWP owners, Enjoy! Thanks goes to christon found this at dssrookie dot com
I tried for the regular. There is no user channel list under settings. It seems we can't use it for regular. OK, any way nice post, CW600 premium people can really take advantage of this.
