Picture freeze
Username: Greatful
Post Number: 52
i have a CW600s premium box i downloaded the CW600PV1.57 file and every hour or so the picture freezes up for about 2 min. it would ok but i record on dvd will there be a new bin?
greg
Username: Brucester
Post Number: 633
all is working good on my 2 cw600p try factory reset and do not forget to in abble the patch f1 000
Username: Greatful
Post Number: 54
not sure what is patch f1 000
greg
Username: Greatful
Post Number: 56
by factory reset,do i have to erase everything
greg
Username: Brucester
Post Number: 635
you will have to go to menu after you do factory reset you will have to scan the sat you are pointed at and if you want ch back in order just go to menu then system setting then system go down to channel movit to SID this will put all channels in order after you do factory reset and scan the sats you are pointed at and to scan sats go menu installation and antenna setting you will see sat names pick the sat your dish is pointed at hope this helps and after that do a auto scan it is red button on botem of the remote then enable the patch with the button on the remote it is the F1 you will see H on the box add 000 it will say patch in able or disable you want it to say inable
Username: Greatful
Post Number: 57
thank you bruce l
greg
Username: Brucester
Post Number: 637
glad to help have a good night i hope you can watch tv
Username: Greatful
Post Number: 58
bruce l i can't get the ppv or vod channels i get the movie,xxx movies i do get one ppv that's on 119 sat but nothing on 110 i did a factory default then blind scan,auto,network,transponder
you name it its been tried
i believe my setting are good what am i doing wrong.
thanks greg
Username: Brucester
Post Number: 638
do you have a switch and if so in your setings go to antenna setting mack sure if you have more then one lmb on your dish if you rember what port you put it in on my box i got lmb at 110 that wire gos to lmb 1 port on my switch so in my setting i put my lmb setting from none to lmb1 and the other dish i have is at 91 so i put it in to my switch lmb2 so in my box i go to menu antenna setting lmb from none to lmb2 if these setting are rong you will get scrambled ch on that sat check and let me no thanks
Username: Greatful
Post Number: 59
found out what was wrong the lnb setting was normal and it should be ocs-dp i get everything now,now if you can help me with this i get a few channels that are weak no quality by moving the dish would you think it would come in i recall when i had my panset 2500 a few channels came in better early in the day but at night they were very weak and did not come in at all.
and one more thing on the radio side siri comes in good but i have a list of cd channels that have high quality but no sound what can i do there.
thank you,greg
Username: Brucester
Post Number: 641
for sound switch the box off and on by the back but count to 10 then turn it on and i to got more ch with my old 2500 pancrap but the ch i did not watch so i did not care but if you do you can go ask at completefta dot com hope this helps with the sound
Username: Greatful
Post Number: 60
thanks bruce you have been alot of help
take care greg
Username: Brucester
Post Number: 646
your welcome greg have a nice night
Username: Greatful
Post Number: 61
hi bruce the samething still happens maybe this will explain it better
i have a CW600s premium box i downloaded the CW600PV1.57 file i get a picture freeze when watching a ppv it happens about every 35 min. it will freeze and come up as scrambled channel for about 30sec then come back on i did a factory reset also a patch still happens so today i redownloaded the file again and it still happens i was watching hoste pt 2 and it did it twice
is there anything i can do to fix this it only happens on ppv xxx not sure about vod
thanks,greg
i also posted this on ftapro support
greg
Username: Brucester
Post Number: 647
im not having that problum with my 2 boxes dont no what to say ill try to find sum info for you
Username: Greatful
Post Number: 62
weredid you get your file from
Username: Brucester
Post Number: 649
i found this site has the cw files first befor other sites hope this helps you [link removed]
Username: Greatful
Post Number: 63
thanks bruce i just joined completefta i installed a file from ftasolution.com
CW600PV1[1].57.rar and i have been recording surfs up its almost over and it's been good so far it may have been the way i downloaded the last two files but good so far
thanks alot,greg
Username: Brucester
Post Number: 650
greg glad to help have a good night
Username: Raby
Detroit, Mi Usa
Post Number: 9
hi guys
i have the viewsat ultra and i have the same problem (freezing picture ) every couple minutes
if some bady have the solution i well thank u in advance
Username: Brucester
Post Number: 654
greg there is new bin out 158 it will fix your freezing picture
Username: Greatful
Post Number: 64
it did come back
thank you bruce, greg
Username: Brucester
Post Number: 657
you are welcome i think this bin is working a lot better for the remote on my 2 boxes i did not have freezing with the old bin but my remote worked like crap this bin fixed all the remote problums hope it works good for you have a nice day
