148 dish epg (for Koolsat 6100 reciever)
Username: Saqeeb9000
Post Number: 177
hi my epg works good for bev 91,82 for koolsat 6100 reciever... so please tell me which channels i need to go for 148 to populate epg..
i tried on geo tv .. no luck...
if any body have 148 dish and koolsat 6100 reciver..please let me know which channel works for epg (currently i have 148,91,82) dishes..
Username: Space_invader
Andromeda M31
Post Number: 176
You can turn off some of the key boxes on channel 8282, except for those for nagra... This may help you get the EPG... If not, try a factory reset and load the fix again... Or check the guide over the net... Don't give up...
Username: Nydas
Post Number: 4995
I think C00LSAT 6100 should have enough memory to load at least 24 hour EPG. If there is a setting somewhere for EPG, turn it on.
Echostar 148W TP 19 Freq. 12486 R SR 20000 FEC 3/4
The EPG is on TP 19. I can never remember whether "R" above stands for horizontal or Vertical. try both.
If you like any of these channels put it in your favourites, go to the channel, then switch off and switch on and you will get the EPG in a little while. You might have to wait for 30-120 seconds for EPG to load.
Polsat 2 607
TVN 24 609
RTP Internacional AmA©rica 615
Geo USA 620
NBN (Lebanon) 778
DISH EPG 36861
Username: Lklives
Post Number: 13748
Attached are channels for each DN/Bev sat you may use for complete EPG population.
EXTENDED EPG: Using any of these channels will give extended EPG data for any/all DN sats.
119w
ESPNA--145
WGN--239
FOXMW--418
CSNMA--424
FOXCN--427
FOXN--436
SNY--438
NHL--544
NHL--550
NHL--552
NHL--554
NHL--557
NBA--572
MLB--627
MLB--636
WGN--881
AUD19--946
SKDL--5802
EPSK1--5814
SIRI--6001
SIRI--6008
SIRI--6014
SIRI--6021
SIRI--6026
SIRI--6027
SIRI--6028
SIRI--6035
SIRI--6040
SIRI--6060
SIRI--6071
SIRI--6073
SIRI--6074
SIRI--6077
SIRI--6080
SIRI--6086'Regular' EPG
If you don't have 119w, the following are lists for each individual DN sat:
61.5w/148w
PLSAT--607
TVN24--609
RTPI--615
GEOTV--620
NBN--778Code:
110w
BIOGR--119
VH1CL--163
MLTRY--195
HBOLT--309
SHOCS--321
TMC-W--329
TMCXW--330
FRESH--499
TMC-W--898
TMCXW--899
129w
SPRKY--257
INFO--258
INFO9--259
SPRKY--5840
INFO--5841
INFO9--5842
WJET--7041
WSEE--7042
WICU--7043
WFXP--7044
WQLN--7047
WAHU--7932
D1000--9901Code:
105w
D105--7000Code:
121w
PLSAT--733
TVN24--734
KINO--737
RTVI--738
ALJAZ--761
MBC--766
118.8w
GEMNI--799
SURYA--800
D118--9903
These next two are for ExpressVu.
82w
FAIRM--716
FAIR--717
FAIRW--718
ABCHE--816Code:
91w
162 VuF2
167 VuF7
218 CHCH/Hamil
240 GLB/Edmont
280 NBC/Boston
296 UPN/Boston
352 Vu2
357 Vu7
410 The Score
510 BBC World
I hope this will clear up any uncertainty on which channels maybe used for best EPG population.
Note: Remember to add 1000 to the ExpressVu channel number if you use Bev channel renumbering.
Username: Nydas
Post Number: 5008
The person is asking about 148W. The answer has already been given and your very long post does not have the answer.
Go and take your pills.
Username: Lklives
Post Number: 13753
61.5w/148w
PLSAT--607
TVN24--609
RTPI--615
GEOTV--620
NBN--778Code:
nalin U are so STUPID!...this EXACTLY answers the original question..and even adds other satellite and which channels are best for EPG..
"if any body have 148 dish and koolsat 6100 reciver..please let me know which channel works for epg"
nalin again, U are dumber, than dumb!
Username: Nydas
Post Number: 5011
LK: You are right you did answer. But what about the UK Sats and the Sats over south America, Japan, China and India? You did not include them in your list. Would that not be a relevant part of the reply? It is only then that people would know how brilliant you are at C/P.
Your post is only 15 inches long. Don't you think it should be at least 40 inches, so that everything else is properly masked off?
Besides, your current worshipper RTAP would not have enough C/P material next time.
By the way, who was it that was complaining of bandwidth usage from irrelevant long posts? It could not have been you, could it?
Username: Lklives
Post Number: 13755
Its not relevant to North American users of DN and Bev, the most common prividers on this continent ....azzhole!
since u are into measuring, open your mouth and I'll shove 9 inches in it!
Username: Nydas
Post Number: 5017
LK: What they gave you at surgery in San Fransico is not worth talking about. For all practical purposes you are just an old girl, bragging away aimlessly and shooting at absent Afghan enemies; those enemies are just ghosts in your mind.
Why don't you take a trip to the VA hospital near you and get your head examined?
Username: Lklives
Post Number: 13757
why don't U suck my cocck!
Username: Nydas
Post Number: 5021
Post Number: 178
thanks guys for help......
Post Number: 179
its still not working
DISH EPG 36861
nalin what does that mean.. is it channel number...
Username: Nydas
Post Number: 5035
I do not know what the channel number 36861 means. That is how it shows up on lyng*sat site.
On one Sonicview 4000, that I am testing, I have Geo USA 620 in the Indian Fav. The EPG is turned on, on the receiver. When I have finished at night, I put it on GeoUSA and switch off. When I switch on next day, I get 48 hour EPG on ALL my Echo 3 channels. If I forget it and do not look at the Sonicview for 2 days, because I am testing a converted Pansat, when I turn on Sonicview I get only next 2 hours till I deliberately switch to Geo and switch off/on.
The converted Pansat gives only 2 hours, no matter what you do.
Andromeda M31
Post Number: 212
Post Number: 207
tomhiro what does that mean........
