please some one help me out with my pansat 2500a. when ever i install any bin file into that it's shows night rider light then i install bin290 file so it's comes back i tried everything to load a new bin please help me how do i load new bin file into.
james follow this post.AV is very knowledgeable for 2500-2700.
AV Gold Member Username: Asharfi
Post Number: 1456 Registered: Aug-06
Posted on Sunday, November 18, 2007 - 01:05 pm: newbies ....
instead of asking the same thing again n again .... go to www.dssworld.co.nr and post your problems and questions there .... i'll help u out there bcoz the speed is kinda faster .... I've posted manu useful guides for Pansat 2500 and FLU owners.
Hello guys, I need help please.... When I go to Antenna Setup and then choose the satellite ECHO3/KU, I select TP 6 with strength signal but I can't save it. It goes back to TP 1. I guess it is locked. How can I unlock it?
rere: I told you the CS_221T has bugs and Chancy replaced it with CS_221Tv2. Can't you understand that? Either you change to CS_222T_Lighning or to CS_223T_Lighning or to jvvh_leaks_222
Nalin, Could you please guide me to get the files or if you can send me the attached file to get CS_222T_Lighning or to CS_223T_Lighning or to jvvh_leaks_222
I already followed your instructions and i went to total fta but coudn't find the files!
night rider lights is an easy fix reset it back the factory settings here is an eg:... open fortec loader in the STB mode look for lifetime ultra load boot_Lifetime Ultra_ver60_040515.bin.. make sure you change settings to BOOT file at this time . now load LTU_flash1_239 factory settings.bin..change settings to FLASH ROM now load lastest bin filei ( bin290T ) there are newer ones out ... using the Pansat STB Uploader B.L. 1.4 .. for FLU you MUST USE chancylands bins they end with "T" i must add If you have newer files than the one in my info use them but if your flu is not 2500a then this info will NOT work for you.I hope this helps
