New member Username: Jhousman6Post Number: 2 Registered: Aug-07 | I just moved here and I have the dishpro dish. I don't konw what the new bin currently is for the converted 2700's and I don't have a clue how to set it all up again, any detailed instructions would be VERY GREATLY appreciated. I am lost all the way down to if I need a switch or not, and what side to hook the cable too. Thank you so much for your help |
Gold Member Username: RtapFL Post Number: 1097 Registered: Jan-07 | follow the first post n this thread.good luck https://www.ecoustics.com/electronics/forum/home-video/405361.html |
New member Username: Jhousman6Post Number: 3 Registered: Aug-07 | Didn't find anything there on how to set this up |
Gold Member Username: NydasPost Number: 5038 Registered: Jun-06 | AV has detailed instructions at this site: I have posted detailed instructions too. Go to https://www.ecoustics.com/electronics/forum/home-video/402679.html Record details of your current antenna setup - particully the details in the individual sats. Look at the first post, and follow the detailed instructions. The only change would be that you should install CS_222T_lightning or CS_223T_Lightning, instead of the UKR BIN Those instructions, when followed properly, do work. If they do not work for you, then tough luck. In your case, when you set do antenna setup do exactly as is your current setup. |
Platinum Member Username: LklivesPost Number: 13767 Registered: Jan-06 | Just run cable directly from the Dish pro plus twin LNB directly to the receiver (no switches)..U will get the 110-119 Dishnetwork satellites, if U align the dish correctly...at least channel 100 and 500 for now.. Then just add current bin CS 223, if receiver has already been converted to a 2700...rescan channels...set default key...wait 2-20 minutes while keys auroroll..watch TV and input antenna settings after loading the CS 223 bin.. 119-disque/port #1 110- #2 type -DP dish pro freq 11250 22-off scan -all |
Silver Member Username: Space_invaderAndromeda M31 Post Number: 190 Registered: Nov-07 | Hey, LK... It's calling you... |
Silver Member Username: Space_invaderAndromeda M31 Post Number: 191 Registered: Nov-07 | Hey, LK... It's calling you... |
Platinum Member Username: LklivesPost Number: 13769 Registered: Jan-06 | M31..well I'm playing golf today and boating Friday, but I can use a change in scenery to the "south"...thanks buddy....water is sure pretty there..U should be there now and not up north.. |
