New member Username: GoldyPost Number: 1 Registered: Jun-05 | Ok so my pansat2500 is totaly gone and i am looking at othere boxes to buy. Any suggestions between c**lsat, viewsat etc. and also there was a forum for newbies that helped you set up your box and i cant find it now any suggestions on that as well. Thanks |
Gold Member Username: RtapFL Post Number: 1092 Registered: Jan-07 | go with the viewsat,sonicview.a lot of people are saying conaxsat but i never personal experience. |
Bronze Member Username: SydfahimPost Number: 14 Registered: Jun-06 | AV, Lk, Nadin I tried to down load b75 to convert my pansat 2500 to 2700 but it gives me nightrider would you help me Thanks |
Gold Member Username: NydasPost Number: 5037 Registered: Jun-06 | syd: Go to https://www.ecoustics.com/electronics/forum/home-video/402679.html Look at the first post, and follow the detailed instructions. The only change would be that you should install CS_222T_lightning or CS_223T_Lightning, instead of the UKR BIN Those instructions, when followed properly, do work. If they do not work for you, then tough luck. |
