Timbre matching to Axioms
Would a SVS PCi+ 23-31 be timbre matched to Axiom surround speakers? Does the timbre match matter on subs?
timn8ter
I've been able to successfully blend subwoofers in by getting a test tone disk and a SPL (sound pressure level) meter, taking measurements across a frequency range from 20 Hz to 200 Hz. I then used a parametric equalizer to ensure that when the subs kicked in they weren't overpowering the rest of the speakers. The best investment I made for controlling bass was the BFD.
http://www.zzounds.com/item--BEHDSP1124P
There's fantastic documentation on how to use it.
http://www.snapbug.ws/bfd.htm
I wholeheartedly recommend it for getting the bass right.
timn8ter
Oh yeah, to specifically answer the timbre matching question: When you get below 100 Hz timbre matching is virtually a non-issue.
G-Man
Very true Tim. Subwoofers, if they are made well and are true subwoofers, have no real timbre or tonal attributes. Those that have tonal attributes are struggling.
