New member Username: Juancarlos707El Centro, CA Imperial Post Number: 1 Registered: Nov-07 | I got two dvc 4ohm subwoofers. They are 800W rms each and I want to wire them both at 1 ohm. But I need to know if you have a amplifier that is 800w rms @1 ohm x1, does it give out 800w to each sub or does that power cut in half to 400w rms to each one. I dont know, any feedback??? You can prefer which amp to use too. Im still looking for an amp and my price range is from $400 to 600 |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 926 Registered: Nov-06 | it divides in half giving each sub about half or the total output... |
Bronze Member Username: BonhamdMichigan USA Post Number: 20 Registered: Nov-07 | 800rms @ 1 ohm would give 400 watts rms to each sub. You would probably need a bigger amp. |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 927 Registered: Nov-06 | MONO amps for subs.... What kind of subs are they????? |
New member Username: Juancarlos707El Centro, CA Imperial Post Number: 2 Registered: Nov-07 | O.k. I get it know. Thanks man |
New member Username: Juancarlos707El Centro, CA Imperial Post Number: 3 Registered: Nov-07 | 2 12" Clif Designs nuclear series. Why u cant hook them up at 1 ohm?? |
Bronze Member Username: BonhamdMichigan USA Post Number: 21 Registered: Nov-07 | you can if they are dvc 4 ohm |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 932 Registered: Nov-06 | |
New member Username: Juancarlos707El Centro, CA Imperial Post Number: 4 Registered: Nov-07 | Alright I got it.. Thaks a lot. U know I got those subs as a birthday present. THey were brand new and looked pretty good. But i dont know anything about that brand. Is it any good. Like Great,average, or crap. Are they for spl or sq. Im thinking spl but dont know. |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 933 Registered: Nov-06 | Whats the model # |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 934 Registered: Nov-06 | Sorry correction on my first post in this thread... ^^^^"it divides in half giving each sub about half of the total output" |
New member Username: Juancarlos707El Centro, CA Imperial Post Number: 5 Registered: Nov-07 | CDnuc12 there the nuclear series. Its alright I got what u were trying to say |
New member Username: Juancarlos707El Centro, CA Imperial Post Number: 6 Registered: Nov-07 | Hello? Any one know if the Clif Designs Nuclear series Subwoofers are any good?? |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 937 Registered: Nov-06 | They have a small diameter voice coil (for 12" woofer I like to see 3" or bigger), foam surround (I prefer rubber because foam falls apart/dry up easier and faster than rubber) and I like to see a higher sensitivity... This is a much better subwoofer: 2076_310069929_153020681_tab=B%2C00.html?compName=PNA_V3_ProductDetailsComponent ,http://www.pioneerelectronics.com/pna/v3/pg/product/details/0,,2076_310069929_1 53020681_tab=B,00.html?compName=PNA_V3_ProductDetailsComponent ......JMO |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 938 Registered: Nov-06 | http://www.sonicelectronix.com/item_8729_Clif+Designs+CDNUC12.html |
New member Username: Juancarlos707El Centro, CA Imperial Post Number: 7 Registered: Nov-07 | I see the clif designs specs. But the poineer website doesnt come through to what sub you want to show me. But Im probably sure the sub your saying is better. Oh well It was free. Later |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 943 Registered: Nov-06 | I'm not saying their bad, they should sound good.. Can't be bad if its free.... Try this one: 2076_4061_232689560%2C00.html,http://www.pioneerelectronics.com/pna/product/deta il/0,,2076_4061_232689560,00.html |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 944 Registered: Nov-06 | 2076_310069929_153020681%2C00.html,http://www.pioneerelectronics.com/pna/v3/pg/p roduct/details/0,,2076_310069929_153020681,00.html |
Silver Member Username: KaerfplSpencerport, NY USA Post Number: 765 Registered: Jun-06 | ^^^Bad link |
New member Username: Juancarlos707El Centro, CA Imperial Post Number: 8 Registered: Nov-07 | haha thanks, yeah its another bad link. just tell me what type of poineer sub it is and ill check out the specs on their website so you dont have to go through all this trouble |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 945 Registered: Nov-06 | http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18351 |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 946 Registered: Nov-06 | Here it is...... http://www0.shopping.com/xPF-Pioneer-Pioneer-TS-W3004SPL-12-SPL-Component-Subwoo fer |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 947 Registered: Nov-06 | Best one..... http://www.abtelectronics.com/product/18109.html Hope this works... |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 948 Registered: Nov-06 | Damn, it don't work..... |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 949 Registered: Nov-06 | Pioneer Premier TS-W3004SPL |
New member Username: Juancarlos707El Centro, CA Imperial Post Number: 9 Registered: Nov-07 | I Checked them out. It has a better sensitivity and 1000Rms. damn for a cheap price. not gonna lie looks like a good spl sub |
Silver Member Username: Sinful_systems7015 INCH WANG... Post Number: 953 Registered: Nov-06 | 150+ SPL with two |
