What is this rated?
Username: Slicknick
Grove, Oklahoma U.S.
Post Number: 40
hey, i'm gonna buy an Alpine SWR-1222D 12" sub, and i was looking at some alpine amps to power it with, i was wondering if the mrp-m650 would be too much power? and does anybody know if it is under-rated or over-rated?
http://www.crutchfield.com/App/Product/Item/Main.aspx?i=500MRPM650&search=alpine +amps&tp=115
Username: The_image_dynamic
San Diego
Post Number: 3100
It is CEA-2006 compliant so by law it has to put out at least it's rated power @ 14.4 volts.
Username: Nd4spd18
Northwest PA
Post Number: 4120
Alpine amps are accurately rated. And while there is no such thing as too much power (you don't have to use it all), a type R will easily take the full output of that amp.
Username: Rovin
4 10 Pioneer...
Post Number: 12491
...WAIT a minute !
1222 is dual 2ohms & that amp is only stable down to 2 ohms therefore u should buy the dual 4ohms model 1242d (& wire the sub to 2ohms)...that amp will take power it good......
Username: Slicknick
Post Number: 44
"1222 is dual 2ohms & that amp is only stable down to 2 ohms therefore u should buy the dual 4ohms model 1242d (& wire the sub to 2ohms)...that amp will take power it good......"
i'm not exactly sure what your saying, why would i need to do that?
Username: Shade
Moxee, Wa U.S.
Post Number: 478
becuz he's saying that amp is 2ohm stable and no lower and the 1222 model will wire down to 1ohm and ur amp cannot do that, so get the 1242 instead.
Username: Nd4spd18
Northwest PA
Post Number: 4129
Good call Rovin
As he said you need the dual 4 ohm sub for use with that amp. If the amp were 1 ohm stable you would get the dual 2 ohm sub.
Username: Rovin
4 10 Pioneer...
Post Number: 12494
'''..that amp will take power it good....'''
should have been..that amp will power it good....
trust me - get the 1242 model instead ....
Username: Slicknick
Post Number: 45
ah, i get it now, i was not aware of that. thanks guys. i'll get the 1242
