How do i wire this thing???
Username: Highstone
Post Number: 424
hi guys.. ok .. i have a a6004t amp (4 ch) i'm using 2 channels for my (2) 6.5" and i want to bridge the other 2 channels for a sub... i have MA120QS which is single voice coil 4 ohms. now how do i bridge 2 channels to this sub to get 4ohms of resistance?
a diagram would be really nice..
thanks
Username: Logan__tille
HEMIKLR
Post Number: 9072
connect all the postives together and all the negitives togather.
Username: Rovin
4 10 Pioneer...
Post Number: 12488
since u have a single cloi sub all u have to do is look at the amp manual which will show u which terminal to connect the +&- terminals of the sub & how to adjust the amp's filters\settings....very simple to do....
Username: Carguy
Post Number: 6653
I wouldn't use the 4 channel amp to power a sub. It won't produce enough power and will use up lot of current. Save some money and get A8000T amp for $140 new.
To bridge 2 channels, you usually take one pos from channel 1, and neg from channel 2. Your manual will tell you exactly which to use. Whatever you do, don't guess.
