For the ones who have experience with both.....
Username: Ton
Post Number: 158
...which one of these two setups you'll choose for both SQ, SPL( daily groundpounder), 4x SE 15" Sealed or 4x RE SE 12" Ported, both will have the same air volume between 7.2 and 8 ft^3. the ported will be tuned at like 32-34 Hz, and both will be powered by either 2x Sundown SAZ-1500D or 2x UsAmps MD-2D,
Also, do you think the 4x ported will handle the power I'm planning to use?
thanks, Aruman.
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 5513
I would have to go 4 12's ported man :-)
~8cuft w/ ~110sq inches of port tuned to 32hz would be fun.
Username: Th3pwn3r
Post Number:...
Post Number: 5842
Hittin the lows is fun but hittin the higher notes can be fun too though :-)
Username: Skibum12189
Cleveland
Post Number: 2047
what kinda car do you have?
Username: Ton
Post Number: 159
trunk car, toyota corolla
Cleveland
Post Number: 2049
can you even fit 8 cubes in a corolla?
you might have to build the box IN the trunk which might suck...4 sealed bm's should get pretty damn loud
Cleveland
Post Number: 2050
i mean se's
Username: Nd4spd18
Northwest PA
Post Number: 4077
So pretty much you want SQL, something thats loud AND sounds good?
Ported box with a low tuning is the way to go for that.
Username: Ton
Post Number: 160
thanks guys, yes Cal, I will able to fit 8ft^3 in my trunk, half fiberglass and halve mdf, And if I have to modified the car to get more space, I'll do it.
I was leaning more toward the 4x ported, I want Super loud and good SQ, but since i don't have experience with RE products, I asked this questions.
2 people says the 4x 12's ported and 1 says 4x 15's Sealed, this mean that these two setups are very similar in loudness and SQ?
Here's a pic, anyways thanks guys.
Username: Ton
Post Number: 161
bump
