What High Quality amp to get?
Username: Jeremy812
Hey what's up everybody? I'm new on here and I am planning on getting (2) Audioque HD3 15's when they come out with them again. I am going to need a good quality amp that will give it's rated power. I am looking for something that puts out 2000 to 2500 watts at 1 ohm. So my question is what would you guys suggest?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13142
budget
Username: Jeremy812
Well my budget is going to be somewhere in the neighborhood of 600 or 700 dollars and I was thinking of possibly getting an orion 2500d but I don't know yet. Also would ebay be a good place to get an amp?
Username: Santa_fe
02 Hyundia Santa Fe, 120.3 db not...
Post Number: 338
go phoenix gold,
Username: 420alldaylong
Post Number: 2908
http://www.realmofexcursion.com/
Realm Of Excursion store has a Powerbass XA3000D for $629.
Post Number: 2909
Username: Jeremy812
Are powerbass amps known to be very good because I haven't known anybody personally that had one. Also what about the soundstream 2000d that's 629.99 on the realmofexcursion website. I know soundstream used to be good but I don't know if they are anymore.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 718
Ive heard the the XA's put out rated power and im recieving an ASA1500.1D in the mail today. im gonna get it bench tested when ever I get the chance.
Username: Th3pwn3r
Post Number:...
Post Number: 5814
Jeremy for that kind of power you should save up a tiny bit more and get yourself a DD M3 amplifier.They can be found used for about 750-850.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5024
RD audio!!
Username: Drant19
TX
Post Number: 61
heres a soundstream pca3500 for $500
http://www.millionbuy.com/soupca3500d.html
Username: 04redmach1
Columbus, GA USA
Post Number: 1442
For $850 shipped I can run a RD 3250.1 to your door :-)
Kevin
lowhz01@yahoo.com
Username: Nd4spd18
Northwest PA
Post Number: 4064
" heres a soundstream pca3500 for $500 "
Hell no! Aviod that amp like the plague. That particular amp is known to fry when run at 1 ohm. Soundstream couldn't fix it, so they no longer make that particular model.
The DD M3, or the RD 3250 from Kevin are great amps. The powerbass is good also.
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 448
hunterw got the rd3250.1 and he said its a very good sounding amp
Username: Drant19
TX
Post Number: 63
someone else on here told me that the picasso amps were good amps... guess i was wrong.
avoid that amp then, my bad
Username: Nd4spd18
Northwest PA
Post Number: 4103
" hunterw got the rd3250.1 and he said its a very good sounding amp "
Amps do not have "sound". The take a low power signal, and ideally, create an identical high power signal. The only external factor is distortion that can be introduced.
Username: Hdubb
Team Revolution
Post Number: 2874
lol
Username: Cblaze
Post Number: 457
compare different amps that can do around the same wattage,on the same set of subs,and u will see a difference
Username: Jkidder
Gunshine , State Flawda
Post Number: 2719
ms- slew rate cough cough
Username: Th3pwn3r
Post Number:...
Post Number: 5882
M3 once again.It won't beat up your charging system,they're very efficient amps.
Username: Juliob
Post Number: 5042
hahaha M.S i was going to post that thing haha i'm still laughing lol!
