Where can I get a voltmeter for my dash?
Username: Mj23dynasty
Harrisburg star city, Pistolvania USA
Post Number: 216
I don't know if I'm calling it the right thing but I want an accurate voltmeter you know the thing that tells you how many volts your system is running at so I can monitor my stuff since I'm not upgrading my electrical. I want one I can instal in my dash with preferably with a blue LED display I hope there not to expensive and are very accurate
Username: Hdubb
Team Revolution
Post Number: 2823
rockford makes one. it cost me ten bux.
Username: Kaprese
Walstonburg, NC USA
Post Number: 503
I am interested in one also I just wasn't sure were to get dem
Username: Th3pwn3r
Post Number:...
Post Number: 5836
Look up the stinger SVMB or SVMR.I'll get a link in a second.
Username: Th3pwn3r
Post Number:...
Post Number: 5837
Here you go guys.
http://cgi.ebay.com/STINGER-SVMB-BLUE-CAR-AUDIO-DIGITAL-VOLTAGE-METER-GAUGE_W0QQ itemZ140176966849QQihZ004QQcategoryZ50552QQcmdZViewItem?refid=store
Mine works but under-reads my voltage by .2volts. I used a DMM to check for variance.It's easy to install and works pretty well.
Username: Rovin
4 10 Pioneer...
Post Number: 12484
the stinger 1 works very good & it also comes in RED too ,got a red 1 in my ride .....
Username: Jesse59672
OKLAHOMA
Post Number: 773
or maybe your dmm is off by .2
Username: Crayola0
2008 Nissan Versa!!, Wisconsin
Post Number: 2177
They also used to have them on the cardomain store site but idk if they still do
Username: Th3pwn3r
Post Number:...
Post Number: 5839
"or maybe your dmm is off by .2"
Or maybe I'm losing voltage through the 14foot wire that the voltmeter gets it's reading from?Oh yea,that's what it is.Good thing I figured that one out.
Username: Basssquared
Kansas
Post Number: 1485
jesse got PWNED haha thats what he gets for trying to be a smartass lmfao
Username: Santa_fe
02 Hyundia Santa Fe, 120.3 db not...
Post Number: 343
naaa rob ur worng...lol....there must be a whole in the wire along the way and some current is "leaking" out onto the road...thats gotta be it
Username: Th3pwn3r
Post Number:...
Post Number: 5840
"naaa rob ur worng...lol....there must be a whole in the wire along the way and some current is "leaking" out onto the road...thats gotta be it"
Damn,I hope nobody hits that crap and gets into an accident :-)
Username: Nd4spd18
Northwest PA
Post Number: 4076
^^^^^ LMAO at the last 2 posts
Rob brings up a good point though. It won't matter how accurate your voltmeter is if you don't hook it up right. Voltage at the amp is what you want to know, so you will need to run small gauge wire from the amp's + and - terminals to the voltmeter.
Username: Th3pwn3r
Post Number:...
Post Number: 5853
"They also used to have them on the cardomain store site but idk if they still do"
Cardomain sold out to crutchfield I think...which sucks!
Username: Andrew571
Post Number: 1291
Username: Nd4spd18
Northwest PA
Post Number: 4088
Damn Andrizzle thats a nice looking dash installation with that HU and voltmeter. It almost looks factory.
Username: Livin_loud
Do Work Fi Audio
Post Number: 1937
I <3 my tsunami still haven't mounted it in my dash, but i like it in my door pocket.
Post Number: 222
Where did you get that voltmeter from the tsunami one its nice. Do you have to cut a hole on the door panel for that?
