Need info about amp for solo barric
Username: Dustinkicker15
I just bought a 15in L7 Solor Barric and I was wdonering if I only used a 1000 watt amp would I still need a new altenator and would it still sound good? If not what amp should i get for around 400 to 600 dollars and what size amp do u need to get new altenator?
Username: •cam•
Post Number: 1040
You'd probably be fine with a zx1000.1. What coils did you get?
Username: 20la20
Franklin, TN U.S.
Post Number: 198
get the kicker zx750.1 it is rated at 750 wrms but will put out more like 900-950 wrms at 2 ohms but if money isnt an issue then splurge for the 1000.1 lol.
its dual 4 ohm
Username: Nd4spd18
Northwest PA
Post Number: 3997
Kicker ZX1000.1 will be perfect for that sub.
An no you shouldn't need a new alternator for that amount of power.
Username: Sinful_systems70
15 INCH WANG...
Post Number: 889
I agree with M.S.
thx alot just what i needed to know
1 more thing i havn't been able to find that amp anywhere i looked any sites or stores that sell that amp that you know of?
Username: •cam•
Post Number: 1054
eBay
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16922
sonicelectronix
Username: Somedonniedude
Illinois United States
Post Number: 377
What size alt do you have? or what vehicle?
Post Number: 7
2004 dodge intrepid
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5030
i think he'll eventually need an alternator upgrade. I don't know his listening habits but he might be near the limit.
Do the Big 3 and upgrade your front battery if you see huge voltage drops
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 446
just depends how effecient the amp is u get
