700+ rms @ 1-4 ohms
Username: Jesse59672
OKLAHOMA
Post Number: 760
Just looking for some ideas on an amp that does 700rms @ 1,2,4 ohms. jl 1000/1 too expensive btw ;P
Username: Mj23dynasty
Harrisburg star city, Pistolvania USA
Post Number: 172
i have an audiobahn A8000T that does 800 RMS @ 2 ohms for 100 bucks shipped. paypal only
Username: Jtown
ATX, Texas
Post Number: 728
RD Audio 1000.1D 1100RMS@ 1 ohm, $300 shipped negotiable
OKLAHOMA
Post Number: 761
ok im looking for an amp that does same power through 1,2,4 ohms
Username: Loudon
Post Number: 1963
pg xenon 600.1
Username: Nd4spd18
Northwest PA
Post Number: 3973
You're look for an amp with a regulated output stage.
And it will probably be expensive, those usually are.
Username: •cam•
Post Number: 1038
Why not just choose an impedance?
Edit:
Or get an amp that will do 700 at 4 ohms, then if you need to, just turn the gain down at 2ohms, or 1 ohm, but then, in most cases, you could just run it at 4 ohms.
Username: Jtown
ATX, Texas
Post Number: 735
yeah, why not?
that 1000.1D will do around 700-900wrms@2ohms
Username: Loudon
Post Number: 1964
or u can just go find that pg that will do what hes looking for .. tnhey can be had for cheap
Username: 420alldaylong
Post Number: 2893
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5910
Username: Jtown
ATX, Texas
Post Number: 736
^^^that is a pretty nice amp
Post Number: 2894
800+ watts^^^^^^^^^^
OKLAHOMA
Post Number: 762
not overrated? i mean its probably cheap for a reason right
Username: Th3pwn3r
Post Number:...
Post Number: 5758
Jesse,aren't you the guy who said he hit a 14x with 2 sealed rockford subs in his GF's car?
Username: Nyyfan13
Fi SSD USA
Post Number: 6965
its cheap cause its an open box item....solid amp tho....still why do you need an amp that does that?
OKLAHOMA
Post Number: 763
yeah that be me rob, 144.9 maybe saw a 145.0 for a split second.
anyways yanks i'm getting that tc9 i won off the raffle and its svc 4ohm and just looking for an amp to power it descently
OKLAHOMA
Post Number: 768
bump
