94 Explorer AM/FM CD wiring connector help
Username: Backin72
Winnipeg, MB Canada
This is the JBL Premium Sound single CD system with sub-woofer. I pulled the radio out of the explorer because it dosen`t power on anymore. It would work ok, but once and while stop and then it would snap back on again. Now its dead, nothing, only the lamps inside the radio light. Checked fuses and all that. The radio illumination is all that works, but still no radio sound or CD sound or clock. Have it now on the bench to look into more. I need the actual wiring connector. The black 8 pin on the rear of the radio I think is 12 vdc DC power input. There is another smaller ( 2 rows of 4 pins connector) off to the side, maybe for the power amp.
Can anyone tell me the 12vdc constant power pin, Switched 12vdc, ground pin, the illumination lights of the radio all were working when I pulled it out of the dash. Just want to get it wired on the test bench to find what's the problem of why no radio power and sound . Have a couple of 8 ohm spearkers to test but need where to connect the speaker and 12 vdc leads.
Any help guys? A schematic or anything?
Thanks.
Username: Backin72
Winnipeg, MB Canada
Seriously, no one knows?
