Change of Plans help with subwoofer box please!
Username: Audiosaab
Potomac, MD
Post Number: 56
K so i decided against the sealed fiberglass box i was going to get. does anyone know what the best, and cheapest offered place to get a good carpeted enclosure to house 2 12" alpine type R's 4ohm would be online...it needs to be vented preferably thanks
Username: Nd4spd18
Northwest PA
Post Number: 3963
I recommend www.fishercustoms.com
Username: Talon01
12 audioque 2.5 144.9 ..., Pa Usa
Post Number: 333
or i can build you one if you want to meet up i am in pa. but fisher is good also
Username: Nyyfan13
Fi SSD USA
Post Number: 6961
phil salisbury...hes in PA which is a soid 45 minute drive for you i believe....pick it up from him and save on shipping costs....not too mention he builds great boxes for good prices
Username: Audiosaab
Potomac, MD
Post Number: 58
Q-Logic - 12" Dual-Chamber Sealed/Vented Sub Enclosure <---bestbuys any good for 2 12" Alpine SWR 4ohm running at mono 1ohm from a Hifonics Brutus 1606D 1600rms
http://www.bestbuy.com/site/olspage.jsp?id=abcat0302036&type=category
Username: Tremor1127
Fi
Post Number: 2416
sealed/vented?
whats that mean?
it all starts with the links of best buy enclosures. one of these days you will look back and laugh. maybe.
and change your name, the p dont show up right on some smaller screens. just put pimp if you HAVE to be all gangster or whatever.
Username: Audiosaab
Potomac, MD
Post Number: 59
lol fair enough and it means that it has an option with the box to seal it, and my current box is customed lol im just looking for something quick and easy for a price roughly between 70-150 for a vented box
Username: Audiosaab
Potomac, MD
Post Number: 60
better?
Username: Jtown
ATX, Texas
Post Number: 727
for that price don't waste your money at BB, ask fisher customs or woodlawn carpentry, they may make that price work
Username: Audiosaab
Potomac, MD
Post Number: 61
k thanks and it would be cheaper than that, i can get employee discounts there but ill look into those two again
Username: Nd4spd18
Northwest PA
Post Number: 3970
The box is 100x more important than the sub that's in it. It doesn't seem like it should work that way but it does. The box has to built to the subs specifications. Prefab boxes are not.
Username: Audiosaab
Potomac, MD
Post Number: 62
so basically i should defiantly get another customized box?
Username: Jtown
ATX, Texas
Post Number: 731
correct.
Username: Nd4spd18
Northwest PA
Post Number: 3976
Yep
