Username: Zunna Post Number: 164 Registered: Jun-06
Monday, November 12, 2007 - 02:03 GMT hi is anyone gettin pak and indian chanells with the new bin 221 ???
Username: Yashmatharu Brampton,
Ont
Post Number: 169 Registered: Feb-06
Monday, November 12, 2007 - 03:13 GMT m not able to get hindi channels after loading 221tv2 file in 2500-2700 receiver.
Username: Asharfi Post Number: 1429 Registered: Aug-06
Monday, November 12, 2007 - 03:20 GMT All channels are working the version 2 of bin 221 by Chancysand. Some channels have some default name, for example: channel AAJTAK will have channel name TV 585, etc
Username: Cricpower Post Number: 38 Registered: Jul-06
Monday, November 12, 2007 - 03:45 GMT I don't get Zee Tv, Zee Cinema and B4U...does anybody get these channels?
Username: Gonxggo Post Number: 47 Registered: Mar-07
Monday, November 12, 2007 - 03:47 GMT AV, I am not getting B4U, Z. Looks like I am missing a transponder. Can you help? I don't see TV 59* for any of this channel. I loaded Chancysand v2 bin
Username: Asharfi Post Number: 1430 Registered: Aug-06
Monday, November 12, 2007 - 04:00 GMT B4U = Channel Number 619 .... t9 27 on Echo 3
Username: Cartier1inchdick Post Number: 32 Registered: Nov-07
Monday, November 12, 2007 - 06:10 GMT
Username: Dude123 Post Number: 1322 Registered: Jul-06
Monday, November 12, 2007 - 07:42 GMT Every international channel is working including PPV and adult channel using bin 221 weather its an original bin or chancysand's modified bin
Username: Vittu Post Number: 8 Registered: Oct-07
Monday, November 12, 2007 - 14:25 GMT All international channels including 'desi' are working fine with 221Tv2 file.
Username: Nydas Post Number: 4800 Registered: Jun-06
Monday, November 12, 2007 - 16:53 GMT If you did not do a reset before starting you will get "missing channels". However if you do not see "B4U", look for "TV 619" and so on and then most likely you will find them and can rename them.
Username: Gonxggo Post Number: 49 Registered: Mar-07
Tuesday, November 13, 2007 - 00:00 GMT Nalin, How do you reset? Are you talking about factory setting?
Ont
Post Number: 170 Registered: Feb-06
Tuesday, November 13, 2007 - 04:20 GMT i have pansat 2500 - 2700. I am hooked up to 118.7 but not getting hindi channels after loading 221 tv2. Can anybody help me?
Username: Darvesh88 Post Number: 8 Registered: May-06
Tuesday, November 13, 2007 - 08:37 GMT Sasrikal to all the AUTOROLL fix is out for viewsat plat and xtreme it came out on nov 11th the autoroll fix for CS 4000 5000 6000 came out tonight on ftabins.net install the bin and make sure autoroll is on it can take 5 to 15 minutes for new keys to come in but all channels including indian and PPV should be working with this new bin good luck all new bins are at ftabins.net
