5.25" or 4" NOOB Question
Username: 94_toy
Post Number: 89
Dont laugh this is a serious question. I got a $100 gift certificate for a stereo shop in town and i need some speakers, i was thinking either kicker DS 5.25" or 4". Im going to hook them up to my kicker 100.2 if i put the filter on for only treble then i dont use the bass. my question is for treble will there be a difference in the 5 25 to the 4" as the tweeters are the same size. 5.25" are the maximum i can fit but the 4" are on blowout sale for like $49.99
Username: Nd4spd18
Northwest PA
Post Number: 3975
Kicker speakers are not that good. Just buy some tweeters.
But to answer the question yes it would work.
Username: Loudon
Post Number: 1966
those kicker speakers arent that good ... u ever heard a good set of kicker speakers .. the rs or the ss series ... they are great speakers .. very versatile
Username: 94_toy
Post Number: 90
so they'll have the same output in treble??
Username: Nd4spd18
Northwest PA
Post Number: 3981
Yes as long as the tweeters are the same. But again, you should just buy tweeters if thats what you need. Cheap coxial speakers and kicker in particular are not very good.
Username: 94_toy
Post Number: 91
they are the KS series....any better???
Username: Loudon
Post Number: 1967
i ran ks comps in my car for almost 2 years without one complaint ...
powered off a kx350.4 ... it sounded awesome
Username: Nd4spd18
Northwest PA
Post Number: 3984
I'm not a big fan of ANY kicker speakers......... and why can't you just get tweeters???????? That would be ideal for what you're trying to do.
Username: 94_toy
Post Number: 93
would a pionner 300W 2 channel amp work good for these, "75W RMS X 2 @ 2 ohm", just dont go crazy with the gain??
