On jensen(phase linear)UV8, same as vm9312, wanting to know how to get half sleeve off new unit
Username: Basssnake
I read the instructions and it says to remove the half sleeve to press the metal levers on the both sides to remove sleeve. I can't see where you do this. Is this like my older jensen vm9411 that you have to remove the four little screws to remove the sleeve?? thanks for any info.
