Silver Member Username: ZunnaPost Number: 158 Registered: Jun-06 | has JWH relesed yet....and if not n when it does plz post it here ..thx ! |
Silver Member Username: LroyPost Number: 309 Registered: Aug-06 | You can use Chancy 221T bin it is safe for all converted 2500 boxes..... |
Silver Member Username: Espn3Post Number: 151 Registered: Aug-06 | is GC fixed on Chancy 221T ? thanks. |
Silver Member Username: ZunnaPost Number: 159 Registered: Jun-06 | Chancy 221T bin so is this is the last one..will it work for long..cuz i dun wana put it in and then see the channels goin down again ..will this work for good? |
Silver Member Username: SatgrlPost Number: 471 Registered: Oct-07 | well no one knows becasue when the keys stop rolling u need a new bin because of the 0106 provder ID |
Bronze Member Username: TsconPost Number: 61 Registered: Aug-07 | "Chancy 221T bin" Where is it??? Link please, I cannot find it anywhere, thanks. |
Silver Member Username: ZunnaPost Number: 162 Registered: Jun-06 | does Chancy 221T bin have 0106 provder ID?? |
Gold Member Username: AsharfiPost Number: 1409 Registered: Aug-06 | It has provider id 0106 but u enter keys in provider id 0101 .... get the latest updated bin from |
New member Username: Mani01Post Number: 8 Registered: Nov-06 | Is JVVH coming out |
Gold Member Username: Dude123Post Number: 1313 Registered: Jul-06 | mani read the posts above you..... https://www.ecoustics.com/electronics/forum/home-video/402601.html |
New member Username: Mani01Post Number: 9 Registered: Nov-06 | thnx |
