My Atmega128 goes down after about 5 minutes of watching it. I am using jeepers with SatJammin. Is there another way to get PPV to work without it going down after a few minutes?
Phoenix Loader 1.1.1 is working great with Atmega128. Make sure you erase your card with jeepers about 6 times before using Phoenix and select all the tiers you want. It's harder to use but it is very complete and better than jeepers. You should also make sure that the ISO clock is set to 4.5 and not the 3.68 it's on by default. It's available at most dss sites. Good Luck.
I downloaded Phoenix loader 1.1 but it won't let me open it. I get the error "Run-time error '339': Component 'comdlg.ocx' or one of its dependencies not correctly registered: a file is missing or invalid. I have dish network is that helps
You're going to have to download that ocx file. Google it and you will find a site to download it. It might not be the only ocx file you will need. You will also need DLPORTIO.sys file if you don't already have it. When you download these files put them in your Phoenix folder and it should work.
I got it all working expect for the card. When I write the card with the Phoenix loader, then put it in my receiver it says smart card not inserted properly
Marco a question a friend of mine has a dn 3100 and a black atmega, somebody give him as a useless stuff, now I read your post I would like to know how can we programme it what we do need.
I use Jeepers with the SatJammin v7.8 now. My card is black with pins sticking out of it. i plug my card into the adapter so i can plug it into my computer. i get the most recent keys and click full monty to start writing keys to card.
I am not very good at explaining stuff like this but I am sure there is a tutorials out there with in depth explanations on how to do it
