119 and 110 diseqc
Username: Heyhowru2004
Post Number: 85
Quick questions.
119 goes with which diseqc
110 goes with which diseqc
thanks
Username: Space_invader
Andromeda (M31)
Check your satellite set-up. If you made the satellite installation, you need to remember where you put the LNB input cables into the multi-switch. If you do not remember, check the switch or try different configurations on the receiver set-up. If you have not installed the switch, put them in a configuration you will remember...
Username: Cartier1
Post Number: 1354
joe does not mather if u are using 4x1 diseqc. as long as you put the port number in your configuration . if you assign number 4 then in your configuration you have to use 4 .
the only time it matters when u have a dishpro legacy and u run only one cable for both 110/119
then you have to give number 1 to 119 and number 2 to 110. cuz there is internal switch in that kind of lnb.
if u dont understand what im talking about . stop asking question and go stright to any fta site and read about lnb's & switchs . you will learn more.
Post Number: 86
cartier thanks sooo much...119 is 1 and 110 is 2....watching tv as i type...thanks again buddy
Username: Cartier1
Post Number: 1356
joe it 's nice for future to understand the concept of this machine and accesries about fta . read from time to time it will make you more understand stuff . good luck
