The 220 bins have so many bugss, post your complaints
Username: Bomberman
Post Number: 33
The way it was earlier where you could select which sats to scan was so much better now it's so fuckkking confusing you have to rename and delete tps what the fucckk.
Also it gets stuck at some percentage while scanning and then it doesn't move from there. Sometimes the receiver just turns off during the scan!
When I'm viewing BEV, every 5-10 secs, the no signal thingy pops up, the screen freezes for a couple of secs fuckkin stupid idea to convert my fortec to a shitt pansat receiverr
Also when you turn it on from the back, it takes like 1 min to just start cuz of the b75 thingy and then it freezes before finally turning it on
When is the new bin comin out for flu users and also If someone knows how i can convert it back( DN not workign anyway) that would be helpful.
If you also have complains, post in this thread!
Username: Bomberman
Post Number: 34
I would rather have no tv at all than these fukin annoying bugssss they freak me out
Username: Koko_wawa
Post Number: 55
bin 220 has been working perfectly with me. Try to reload the bin and see if conditions improve. good luck
Username: Mahmoud
hi kaka tell me how to get 220
Username: Viruscauser
Leesburg, Georgia
Post Number: 354
For the channels that it works for, the jvvh_220 works just great. For the channels that don't work, wait for the new bin.
Username: La_estrella
Post Number: 36
jippii.com
Username: Bomberman
Post Number: 33
Posted on Friday, November 09, 2007 - 09:40 pm:
-- the f.... is that you should have been backed up your channel list before updating.
I did when I converted my lovely Panstar 2500a (Pansat re-cloned twice I think)
Then I converted with jvv tools, and every upgrade since 211 has been very pleasant experience, no problems at all following instruction properly there is no way to screw-up your receiver.
--- Just look for a channel list somewhere and download it to your pansat- dont forget to put the proper disecq ports according your setup---
-- This may be transponder updating, turn TP AutoUPDATE off --- (look all your menus and you will find it)
--- I tell you that is not a stupid idea DN is UP except the PPV. --- Not to bad for free satellite! ---
-- 1 minute wow what a time! This is normal -- relax is not the end of the world! ---
-- The bins for the 2500a clones and similar is to convert them to 2700 for DN, otherwise use it for FTA ---
-- Yes you can convert it back, just read all those post spread all over this site and others ---
mmmm.. no complains, thanks to everybody who are helping to enjoy a huge amount of satellite TV, even if where only a channel that will be amazing.
Regards
Username: Mahmoud
Post Number: 7
hi abby can u tell me how to get 220 bin plz
thanks
Post Number: 38
for some channels there could be alternatives like I lost TELEMUNDO but a friend of mine find it on WNEU not to bad.
Regards
Leesburg, Georgia
Post Number: 355
saliha: http://www.dxxtester.com/details.php?file=3580
(xx=ss)
Leesburg, Georgia
Post Number: 356
That's the bin for the CONVERTED 2500>2700 boxes only and NOT for the 2700 boxes.
Username: Dude123
Post Number: 1266
original pansat2700 bin is out
https://www.ecoustics.com/electronics/forum/home-video/402226.html
