Is bin available for international channels (Indian channels) for Ariza 700? If so, can anyone download file here? Help from people like Nalin/Fundoo and other experts expected!
Fundoo, Thanks for your reply. Can you tell me which bin I should download to view Zee sports? I tried 298 and 293. Couldn't see Zee sports with either. Any specific file? Thanks!
"The Fix for the ARIZA 700 if it has not killed your box your very lucky! You may kill it. That fix is just a renamed 800bin. We are having problems with rebooting still and are working on a solution. The fix thats out will over work your CPU were it will no longer work. If you have 8888 on your display your box is now toast!!! It cant be fixed by nobody not even ARIZA or Global can fix that problem. The fix thats out is from the 800 fix I posted this fix is For the 800. The hardware is different in the 700 line Please don't change the Hard ware ID in the 800 fix so that it works on the 700 line doing so will cause you to have a dead unrepairable box! We don't want third party to kill your FTA box so we have not released anything for the 700 line. Once available it will be posted here FIRST on DSSgeeks."
Default Ariza 700 To Pansat 2700 Jtag Conversion Ariza 700 To Pansat 2700 Jtag Conversion Ariza 700 To Pansat 2700 Jtag Conversion Ok folks here is the conversion for the ariza 700 to pansat 2700... Now it is a USE AT OWN RISK and also DO NOT PM ME WITH QUESTIONS there will be a feedback thread started for that....To start you will need the files provided in thread... Also if you not good with jtag do not try .. YOU WILL NEED A JTAG AND ALSO A NULL CABLE TO LOAD FILES Step 1 Read the instructions provided with jtag info.....( a must) Step 2 when done with jtagging do not turn off machine unhook jtag Step 3 open up gt rom loader 27.02 and load pansat 2700 factory bin.. Step 4 load the B75_m fileNow when machine done loading it will reboot do not turn off let it show 8"s goin across then stops on last 8 for roughly 30 sec.. now turn off from back and set up loader...When loader ready turn on from back and at first sign of light hit fix on loader..Do this process for all files... Step 5 open up BL 1.3 loader and load jvvh 209 file Step 6 load jvvh 209 file Step 7 load on the jvvh 211 file Step 8 load the jvvh 217 file Step 9 load the jvvh 220 ( the whole time using the BL 1.3 loader) Step 9 Do blind scans of sats.What u will notice is that your display shows 8's on it dont worry about it at this point just enjoy and watch t.v........And yes your ariza remote will work on this conversion...... REMEMBER READ AND FOLLOW ALL INSTRUCTIONS
These are new and reported to be working well. Use at your own risk. WARNING: Use all files at your own risk. File Type: rar 700 to 2700_jtag[1].rar.rar (632.2 KB, 36 views) File Type: rar All files for conversion.rar (2.55 MB, 35 views)
