New member Username: MrkhanPost Number: 10 Registered: Oct-07 | Hi I check the keys, and they correct as it is, but still not getting any channels, what should I do next? Do I need to look for new bin file for my convert 2700a box? Thank you mrkhan |
Gold Member Username: NydasPost Number: 4715 Registered: Jun-06 | Mr. Khan: Go to this thread and read the last 30-40 posts. https://www.ecoustics.com/electronics/forum/home-video/399896.html |
Gold Member Username: AsharfiPost Number: 1370 Registered: Aug-06 | Firoz Khan, Right now, I don't think that there are any new fixes for the Pansats, including the converted units. |
Gold Member Username: NydasPost Number: 4718 Registered: Jun-06 | AV: Happy Diwali to you and family. |
Gold Member Username: AsharfiPost Number: 1371 Registered: Aug-06 | Oh ... THANKS! ... Same to YOU!!!!!!!!!! ![]() |
Bronze Member Username: India101Post Number: 19 Registered: Aug-06 | Hello Mr.Nalin "Happy Divali" I have one question about Bev I have already try to switch the dish to 91W(Bell ExpressVu) with Dish500 and i am only getting 40% Frequency. What do i need to to increase the frequency. The level where the dish is on 55.1 please i need to get it high so i can watch cricket tommo. |
Silver Member Username: RtapFL Post Number: 936 Registered: Jan-07 | try using these sat finder for calcs. Satellite Finders (Look Angle Calculators) ------------------------------------------------- http://www3.telus.net/rampage/skew.htm (Dish 500 support) http://www.remotesat.com/lookangle.htm http://monsterfm.com/tech/satellite/pointdish.htm good luck |
