New bin at fta.net
Username: Scabz
Knoxville, Tn Us
Post Number: 19
Should I use it ? I usually go to tatalfta. 071109p is the latest. I'm not sure about using it though. Did anyone else use it ? thanks
Username: Dizasta
Post Number: 30
WORKING FINE and Great.
Username: Kacha
Post Number: 14
is this for pansat??
Username: Scabz
Knoxville, Tn Us
Post Number: 22
No viewsat
Username: Sluggp
question...i downloaded the new bin but it did not download as a pgm or a zip file but as a efw file. Do I load my VS with this file or do you have to somehow extract a pgm file?
Username: Sluggp
hello? is this thing on?
Username: Jbourikos
Post Number: 71
ok...i didnt see new ones at totalfta so im not trying any from other sites for viewsat
just be patient so u dont F up ur box johnny doe
Username: Rtap
FL
Post Number: 931
were did you download it from.
Username: Sluggp
ftabin.net and also it downloaded the same way at total.
Username: Birdwatcher
Post Number: 546
hey jb, dont tell any newbies about the viewsat page cuz theyll just hog it up all day when the file comes out
Username: Sluggp
very helpful dvd...thanks...
Username: Drmunna
Post Number: 40
john doe...
should be .pgm after extracting zip, do it again
Username: Rtap
FL
Post Number: 932
lol.your right about that dvd.
Username: Rossyjess
Post Number: 135
link viewsat xtreme in ftabins.net http://ftabins.net/showthread.php?t=12913
