Recommendations for 4-shelf audio rack
Username: Jazzman71
Phoenix, AZ USA
Post Number: 122
Looking for a quality audio rack for around $1,200 or less. Have looked at Adona and they seem like a good value. Any experience with those, + and -? Are there others in that range I should look at as well. It will be holding a TT, tube phono stage, CDP, and tube integrated amplifier. Thanks.
Username: Mike3
Wylie, Tx USA
Post Number: 1201
Neil,
I wish I could be more specific, but my rack which I bought at John Fort Audio in Dallas has four shelves and would be perfect for what you want at ~$600. Let me know if you would like more info on my dealer.
Regards,
Mike
P.S. I have removed the second shelf from the top on the rack as the Saturn is a top loader.
Username: Jazzman71
Phoenix, AZ USA
Post Number: 125
Mike, thanks for the pic. What are the shelf materials?
Username: Mike3
Wylie, Tx USA
Post Number: 1203
They appear to be pressed (wood grain finish) laquered MDF. They sit on the welded pointed tips of screws driven through the corners of each welded shelf frame. Essentially the steel frame surrounds the MDF shelf with only the screw points coming in contact with the shelf. Like to reverse of the spikes on the bottom of each leg of the stand.
Need to Register?
Forgot Password?
Enable HTML code in message
