What would be next ahead of the Extreme and then what is next above that. Looking to get a new box for another room. Do you set these boxes up close to the way you do the extreme.
yeah, all are similar. U can get a vs ultra for 165, u can program it the same way OR simply by cpoying the bin file to a usb stick and inserting it in to the box and using the remote to do the rest. Sonicview 4000 the same.
