Loud efficient SQ subs
Username: Nd4spd18
Northwest PA
Post Number: 3732
Looking for suggestions on subs for my next system......... going for SQ but loud.
So I'm pretty much looking for 12" SQ based subs with low Fs (I want it to have real good low end) and high SPL efficiency.
So far I've come up with:
Fi Q
IDMax
Now the IDMax is mad expensive, $500, and the 12" Q only has a 85 db spl rating.
So I want something similar to those subs but more efficient and reasonable price. Or does that not exist?
Username: Nyyfan13
Fi SSD USA
Post Number: 6878
Icon
Havoc
RL-s
Revo when they come out
Mag
i know im overlooking some more....
Username: Cenus
Ohio
Post Number: 3808
IMHO i look into an AA avlanche motor, low end monster with great sq and will get loud.
"the 12" Q only has a 85 db spl rating."
wow i figured you of all peole MS would know that sensitivity means pretty much jackshit in car audio, that specs means is uselesss as far as im concerned.
Username: Nd4spd18
Northwest PA
Post Number: 3734
Useless...... hardly. While that rating is not everything it is an indicator or the sub's efficiency.
A sub with a 93 db efficiency will be louder than one with 85 db rating on the same power. (Assuming both are in their optimum enclosures)
Yanks, thank you for the suggestions
Username: Cenus
Ohio
Post Number: 3810
"A sub with a 93 db efficiency will be louder than one with 85 db rating on the same power.:
wow, sensitivty and efficiency are too very different specs. the 1w/1m is sensitivty not efficiency ehich is a useless spec imo.
Username: Nd4spd18
Northwest PA
Post Number: 3736
Getting back on topic: any other suggestions?
Username: Basssquared
Kansas
Post Number: 1448
did i just see M.S. get PWNED???? nice try on trying to change the subject.
Username: Mmaudioconcepts
Murray, KY
Post Number: 304
in theory MS is right
Username: Tremor1127
Fi
Post Number: 2386
i would try to find something along the lines of soundsplinter and tc sounds.
Username: Nd4spd18
Northwest PA
Post Number: 3737
^^^^^ thank you........
And change the subject? Try getting back on the subject of the thread.
Fi
Post Number: 2387
theres some avalanche 12s on CA.com right now i think.
and an 18" avalanche that is MINT for 250 shipped...
how much power do you have?
Username: 420alldaylong
Post Number: 2879
OZ Audio
Eclipse
Diamond
Infinity KAPPA PERFECT
MMAT P3.0
JBL W12GTi
Username: Skies
Courtenay, British Colu... Canada
Post Number: 827
Sensitivity: the amplitude of the waves created by a subwoofer, usually given in 1w/1m, measured in decibals?
Efficiency: Input/output comparison. ex. 1w in = **dB at 1m distance?
Or am I way off?
Username: Skies
Post Number: 829
But anyways...
Agreeing with Tremor, Soundsplinter and TC Sounds sound like they're right up your alley...
Infinity Perfects are very nice, and also check out eclipse aluminum.
Fi
Post Number: 2388
"Agreeing with Tremor, Soundsplinter and TC Sounds sound like they're right up your alley..."
any of those subs are nice for real sql. linear voice coils arent punks...
my soon to be home theater sub... :-)
http://www.soundsplinter.com/images/rlp18-side-angle-sm.jpg
Username: Denali_on_22s
You can call me Scroog...
Post Number: 3045
Hertz audio Mille ML3000
Username: Nd4spd18
Northwest PA
Post Number: 3741
" how much power do you have? "
3000 watts. I forgot to say in the first post, I'm lookin to do 4 12"s here, so subs about 800-1000 watts each.
So far I haven't found any SQ subs more efficient than the Fi Q for similar price, that handle that power.
Username: Th3pwn3r
Post Number:...
Post Number: 5633
M.S.,make sure you have that car sound deadened to the max or you'll lose the SQ of your nice sounding subs but I'm sure you know that.
Username: Adddisorder
Palm Beach, Florida
Post Number: 5442
havoc maybe.
just wondering whats the point of going for SQ with 4 12s?
Username: Santa_fe
Post Number: 318
q-power makes some great SQ subs, thats what i bump and i love em.....the high end stuff is pretty good for the price....anyhitng past the silver series really
Username: Nd4spd18
Northwest PA
Post Number: 3749
Mat dope:
The goal here is to create a very loud SQ system. The most cone area I can fit is 4 12" subs.
Rob:
Don't have any sound deadener, and I don't think it would really do a whole lot for my old Blazer. These trucks are known for having almost eveything on them rattle. Rear window latch, overhead console, door panels, just about every interior piece. Not much can be done about it.
Username: Insearchofbass
Post Number: 7020
yeah my buddies old blazer is hittin 140.6 db at idle with four 12's and he rattles and comes close to leaks at the tailgate area too I think
Username: Cenus
Ohio
Post Number: 3818
back to topic, read this MS you might learn something.
But there are other factors contributing to the overall system efficiency and resulting output levels in a car. The speaker enclosure adds several SPL components, especially using a ported system. The vehicle has what's called "cabin gain," or the many resonances set up as the closed vehicle functions as a resonance chamber similar to what happens inside a loudspeaker enclosure. These items might increase the system sensitivity value by as much as 6db or even more, and increase the overall system efficiency from the lowly speaker averages of 1 or 2% to 50 or 60% or more.
So a simple calculation beginning with the speaker's sensitivity rating and working up by adding 3db for every doubling of input power will only tell you part of the story. (BTW, the raw SPL difference between 1 watt and 1000 watts is +30db.) It only indicates what the speaker would do in a free air anechoic test chamber at 1 meter away. A better method is to test the system after installation and determine the overall system sensitivity. Then a calculation to determine required wattage to achieve a particular db SPL value will have much more meaning. Also realize that SPL decreases with distance at a rate of -6db for each doubling of distance. So if the output is 87 db at one meter, at 2 meters the output will be 81 db. It is critical to know where the test mic will be positioned in relation to the speakers to calculate a predicted output level.
By the way, loudspeaker efficiency is a measure of how much incoming electrical energy is converted into acoustic energy. Often speaker manufacturers will not give you this value, but for good quality loudspeakers a typical value might be between 0.2 % and 2 % and means that only 2% of the amplifier signal is actually being converted into sound, the rest is being wasted as heat. Some high efficiency subwoofers might get as high as 10% or 15%, but high efficiency speakers like compression drivers designed for pro audio can be almost 100% efficient (100% efficiency is 112db/watt-meter.) You can convert the listed sensitivity number into an efficiency using this formula: Efficiency = 10E(Sensitivity in dB - 112)/10
Post Number: 7030
"Also realize that SPL decreases with distance at a rate of -6db for each doubling of distance."
shouldn't that read 3 db not 6db
Username: Cenus
Ohio
Post Number: 3822
im pretty sure its -6db when you double the distance, if not well im sorry.
Username: Nd4spd18
Northwest PA
Post Number: 3752
Dustin I doubt you even understood all of what you just posted, or you wouldn't have said "read this MS you might learn something".
" a simple calculation beginning with the speaker's sensitivity rating and working up by adding 3db for every doubling of input power will only tell you part of the story. "
As I have already said, the SPL 1w/1m spec is not an exact measurement of how loud the sub will be. It IS useful for estimating one subs potential to be louder than another.
" But there are other factors contributing to the overall system efficiency and resulting output levels in a car. The speaker enclosure adds several SPL components, especially using a ported system. "
No sh!t. Thats why I said "assuming both subs are on their optimal enclosures".
Now I don't want to hear any more about this in this thread.
If anyone has any other sub choices, or knows where to get any of these subs for around $250 or so I'd like to hear that. Thanks.
Username: Cenus
Ohio
Post Number: 3826
one last thing then i'll let it die, did you even read the last paragraph?
Username: Loudon
Post Number: 1924
rd sonance
Username: Jkidder
Gunshine , State Flawda
Post Number: 2517
icons all the way
Username: Mike11202
DD9515G VFL 200.1 = : , Sewell, NJ US
Post Number: 1073
4 Image Dynamics IDQ v3 10" on 2000rms
Username: Frkkevin
Post Number: 4053
not once was the 04/05 RE XXX brought up :-(
i'd vote a 12" Mag or 12" XXX
also a MKI or MKII Adire Brahma
Post Number: 7122
four idq 12's are $80 each somewhere on the net plus shipping but I cant find the old post
Username: Nyyfan13
Fi SSD USA
Post Number: 6943
"not once was the 04/05 RE XXX brought up "
only reason i didnt mention it is cause it would be difficult to find 4 of them.....it would just take more time to find them
Post Number: 7123
those idq 12's were new and it was posted within the last 2 months it was a post about sq I think
Username: Mike11202
Post Number: 1074
the IDQ V3 12's are supposed to come out sometime this month..
Fi
Post Number: 2407
""not once was the 04/05 RE XXX brought up "
only reason i didnt mention it is cause it would be difficult to find 4 of them.....it would just take more time to find them"
x2
Username: Nd4spd18
Northwest PA
Post Number: 3890
" not once was the 04/05 RE XXX brought up "
Kevin that's the first sub I thought of when planning for this system. In fact my favorite system that I've ever heard was two XXX 18s.
The thing is, I want the subs new.
Username: Frkkevin
Post Number: 4054
there was 4 18"s that sold on CA.com .. i think theres actually two of the 15" XXXs on there now.. and why do they have to be new?
as long as you buy from a trusted person with a good rep, see all defects shown in the pics you request and know the sub was not abused.. your fine..
sounds like a lot but its really not.. ive bought nearly all my current setup used and saved a ton of cash doing so.. given i have no warranty but whats that matter? if you have good equipment and it is installed properly you don't need warranty :-)
I'm in love with my XXX .. running it still in my port wars box lmao.. did a 142.2dB @ 48hz in a sealed box 1.4cu.ft before displacement.. I was suprised ... but what really gets me is how damn good it sounds
Username: Th3pwn3r
Post Number:...
Post Number: 5706
In all honesty I think you should stick with your DD M.S. .You wouldn't be able to take advantage of the SQ subs output because you'd be hearing all the rattles which doesn't sound good.This is the reason I decided not to run 4 15'' Mags back in the day.I recommend that you tear apart your vehicle and sound deaden the entire thing and then put your DD back in there.You might be surprised what you hear.
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 492
Havoc 12D2 Fs: 30.9
ICON 12D2 Fs: 29.9
RL-p 12D2 Fs: 23.4
RL-s 12 Fs: 30.9
Username: Nd4spd18
Northwest PA
Post Number: 3910
I appreciate the input Rob, but it's not just the SQ factor that I'm going for....... I really want something with better low end, which SQ subs are good for. DDs tend not to like anything below about 35-38 hz.
I figure if I replace my one 9515 with four 12" subs on the same power, it will probably even gain SPL in addition to low end.
-apem
Post Number: 15677
you should go with 4 sound splinter rl-p 12s.
Username: Nd4spd18
Northwest PA
Post Number: 3918
Chad I may just do that....... those subs look badass. Right now it's between those and Fi Q
Username: Th3pwn3r
Post Number:...
Post Number: 5715
Will you be selling your 9515 M.S. ?Also what series is it if you are?
Username: Nd4spd18
Northwest PA
Post Number: 3920
Yes I will most likely be selling it come summer time when I do this new setup. It has an F series. Dave (drivingreckless) has offered $325 for it but when I comes time to sell I'll see if anybody wants to beat that
-apem
Post Number: 15680
i am thinking of switching my subs to the rl-ps. the rl-s are real heavy and require a large box. it takes up my whole trunk space. lol. but i just can't seem to part with my rl-s's. they sound sooooo damn nice. lol. i even started a for sale thread a couple of minutes ago only to delete it right after. lol.
hahahaha rob you collecting dd subs now or something? lol. your sub should be arriving there this week. forgot to mention there is a little chip on the magnet. i really did forget so if you don't want it i'll understand and fully refund your money. not only that, i'll send the ups guy out there to pick it up so you don't have to ship it.
oh and the chip on the magnet doesn't affect the performance at all.
Username: Th3pwn3r
Post Number:...
Post Number: 5718
"forgot to mention there is a little chip on the magnet."
You guys need to lift weights or something so you don't drop any more precious,heavy subs.It was either you or Charlie who did it!Shame on one of you guys.
-apem
Post Number: 15681
it was charlie man. come on. lol do you think i would drop a sub? lol. naw charlie bought it like that.
Kansas
Post Number: 1461
LMFAO at Chad hahahaha oh yeah well i forgot to tell you i dented in the front end of the car but dont worry it dont affect the performance at all lmfao hahahaha just playing Chad
