Bronze Member Username: Iwrk4satanPost Number: 61 Registered: Jul-05 | I am looking to get a new 2008 Honda Accord coupe in the next couple of months. I like the way the inside dash looks as is, with the GPS and all, so I'm thinking about not replacing the HU. I was wondering what direction you guys think I should go. The car comes with "premium audio" which is 7 speakers and a subwoofer, but I'm pretty sure I know what that means -- sounds good to someone that's not really that into music... I'm wondering if I really need to buy something like the JL cleansweep (or anything else that anyone can recommend?) or if I could just do the job with a Line Out Converter. I already have most of the other equipment: 12" v3d4 IDMAX in a 2.5 cuft ported box JL 500/1 JL 300/4 but I'm leaving my old component speakers in my old car. Another question is, is it very important that I get new componenets (I was looking at some CDTs, maybe the HD62?). I'm assuming I won't be able to run the stock speakers amped, and even if I did there's no way they'd keep up with the power. So basically any feedback from anyone that's run a nice system without an aftermarket HU would be great. What I should focus on and what I can live with out? Thanks. |
Bronze Member Username: Mj23dynastyHarrisburg star city, Pistolvania USA Post Number: 78 Registered: Oct-07 | get infinity kappa perfects for comps these are the sexiest sounding comps ive heard so far |
Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 4501 Registered: Apr-06 | buy my HU eclipse cd8445 for 170 shipped!!! or upgrade with my eq for 40 shipped |
New member Username: Patrick80Post Number: 5 Registered: Nov-07 | dave you idiot. |
Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 4504 Registered: Apr-06 | =P |
Gold Member Username: Nd4spd18Northwest PA Post Number: 3697 Registered: Jul-06 | " get infinity kappa perfects for comps these are the sexiest sounding comps ive heard so far " Wow, you obviously never heard a high end set of components. CDT HD62 and that JL amp would be great |
Bronze Member Username: Mj23dynastyHarrisburg star city, Pistolvania USA Post Number: 87 Registered: Oct-07 | I was being sarcastic |
Gold Member Username: Nd4spd18Northwest PA Post Number: 3703 Registered: Jul-06 | Umm really cause you just posed this thead https://www.ecoustics.com/electronics/forum/car-audio/401681.html |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 4022 Registered: Nov-05 | drivin.. i would have bought that h/u from you if i had known it was for sale.. bought some already tho |
Gold Member Username: Denali_on_22sMoney man, blowin Post Number: 3026 Registered: Feb-06 | stop worshipping the devil |
Bronze Member Username: Iwrk4satanPost Number: 62 Registered: Jul-05 | My original post was asking about the JL cleansweep and whether I really need it, or if I could just run my system with a Line Output Converter... |
Gold Member Username: JohnfiacA-ToWn, 9515 thumpin... What u bumpin? Post Number: 3778 Registered: Mar-06 | LOC sucks id rather mount a second HU under the dash then continue using the LOC\Stock HU.... New cars need to start coming with RCA-Preouts on the stock HU's.....and stop integrating the whole car into it... >.< |
Gold Member Username: Nd4spd18Northwest PA Post Number: 3721 Registered: Jul-06 | Yep LOCs suck. If you have to use the stock HU the cleansweep would be the way to go. But a new HU would really be best. |
